20 Most Recent
Royal Orca ASF5000X Shredder Questions & Answers
The shredder stopped and we
Assuming that its not jammed,??.... if its dead and you have no lights, no power etc etc...then you may have blown pcb inside machine...call Royal at 1-800-524-0799 for parts assistance.
Royal Orca 9512
there are 2 plugs in the back. one is on a short cord, the other is the regular power cord. BOTH must be plugged in. also, the shredder must be properly situated on top of the base so that the button inside of the back right good is depressed. last, there is a safety behind the bin that must also be depressed. mine broke--i have a piece of wood jammed in there to hold the button in.
Plastic Gear
call royal spare parts department at 1800-222-2310 they will
ship you a gear for about $6 + shipping
Paper not going down
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad
pc board, contact manufacturer for more info.
Where can I get a Manual for a Royal Scriptor ll Typewriter?
You can try searching for a manual for the Royal Scriptor II typewriter on the manufacturer's website or on websites that specialize in providing manuals and instructions for various products. Additionally, you may be able to find a digital copy of the manual on online marketplaces or auction websites, such as eBay or Amazon. If you are unable to find a manual online, you can try contacting Royal's customer support for assistance in obtaining one.
Royal AX160 advances paper at an angle why?
you might need to calibrate a part of the typewriter in order to fix this or there might be broken part of the typewriter.
Please verify how the paper should be advanced based on the typewriter manual. And if it's different in the manual, then you might need to call Royal directly to ask for the closest repair shop you can send the typewriter to so that the issue can be fixed.
Thank you.
