20 Most Recent Royal 1280MX Shredder Questions & Answers
open unit and look for loose connection.
Royal 1280MX... | Answered on Jul 22, 2017
For parts assistance contact Royal at 1-800-524-0799.
Royal 1280MX... | Answered on Feb 19, 2013
Yes,..for replacment parts contact Royal at 1-800-524-0799.
Royal 1280MX... | Answered on Jul 20, 2011
For parts and pricing contact ROYAL at 1-800-524-0799.
Royal 1280MX... | Answered on Jun 18, 2011
The last one I took apart you had to approach it from the bottom. Remove the lower bin, then start working on screws on the bottom of the shredder. The top part should then come off so you can get to the fuse.
Royal 1280MX... | Answered on Mar 25, 2011
Replace the fuse...not what is written on the circut board....Radio Shack or any electrical repair outlet will have fuses.
Royal 1280MX... | Answered on Feb 13, 2011
If it wont go back or forward then your only recourse is to open it up and "manually" attempt to turn the motor and/or gears untill you can clear the paper. Dont put so much in at a time; and make sure you regulaly oil the machine.
Royal 1280MX... | Answered on Jan 07, 2011
Have you ever oiled the machine.?????
Cross cut shredders need to be lubricated due to the amounts of small paper and dust generated.
Get some "shredder oil" run the machine in reverse and pour some of the oil onto the cutting blades...then when you shred paper put some oil onto a sheet of paper prior to putting it in the shredder. How often do you oil it??? depends how much shredding you do.
Royal 1280MX... | Answered on Nov 21, 2010
If it wont go forward try cleaning the "eyes"...if that dosnt work you may have "fried " the PCB inside...contact Royal for parts assistance at 1-800-524-0799.
Royal 1280MX... | Answered on Nov 11, 2010
Yes if there are no lights/dead then you have likely "fried" the pcb inside. You can contact Royal at 1-800-524-0799 for replacement parts and pricing.
Royal 1280MX... | Answered on Nov 08, 2010
If you cant hear the motor running but you hear a click when you insert the paper it sounds like the eyes are ok so its likely the pcb thats defective...give Royal a call at 1-800-524-0799 for parts assistance.
Royal 1280MX... | Answered on Oct 19, 2010
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Royal 1280MX... | Answered on Sep 06, 2010
If its dead and there is no power you have probably lost the pcb inside the machine...call Royal at 1-800-524-0799 for parts advice.
Royal 1280MX... | Answered on Aug 29, 2010
Pour some shredder oil onto a sheet of paper and shred the sheet of paper...do this a few times to get the oil down into the cutting blades.
Royal 1280MX... | Answered on Aug 22, 2010
Contact ROYAL at 1-800-524-0799
Royal 1280MX... | Answered on Jun 02, 2010
Royal 1280MX Shredder Logo
Popular Tags
30 questions posted
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Ed
Ed
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Royal Office Equipment & Supplies
Most Popular Question
royal paper shredder head sc180mx some
  • Office Equipment & Supplies
