20 Most Recent HP iPAQ 910 Pocket PC Questions & Answers
I downloaded the upgraded ROM
why not ask < HP>>>>??? its old, almost nobody uses these now.... are you going to spend money on this thing? why change the BIOS? ROM best is not to unless you know the BIOS update fixes a known issue you have, no issues stated. https://h30434.www3.hp.com/
7/17/2017 11:19:56 AM • HP iPAQ 910... • Answered on Jul 17, 2017
0answers
Hello i have an ipaq 910 and my touch screen is
Calibrate the touch screen.
12/2/2009 2:35:16 PM • HP iPAQ 910... • Answered on Dec 02, 2009
Need to find out what the charger for it and the
What model HP iPAQ?
10/28/2013 6:51:37 PM • HP iPAQ... • Answered on Oct 28, 2013
0answers
0answers
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
What kind of screws open the backside of an HP Envy PC
The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/13/2024 5:33:03 PM • HP Computers &... • Answered on Mar 13, 2024
How do I open the back of an HP Envy PC, and What kind of screws open the back please.
Great questions, but two questions edited into one. The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/12/2024 6:00:48 PM • HP Computers &... • Answered on Mar 12, 2024
2answers
What to try now hp omen dv7 battery issue
If calibrating the battery didn't work for you you could try a hard reset of the battery:
3/6/2024 9:11:06 PM • HP Computers &... • Answered on Mar 06, 2024
2answers
I have installed 4G RAM, Is that the MAX supported or may upgrade to more ?
Memory Max Maximum supported = 8GB
2/17/2024 5:55:53 AM • HP Computers &... • Answered on Feb 17, 2024
3answers
I have an HP Pavillion533w that will not turn on when I press the power button.
Here are troubleshooting steps for when your computer won't start:
2/15/2024 7:54:52 PM • HP Computers &... • Answered on Feb 15, 2024
2answers
Why won't my HP tower computer turn on?
Here are some troubleshooting steps for when your computer won't turn on:
2/15/2024 7:54:39 PM • HP Computers &... • Answered on Feb 15, 2024
HP iPAQ 910 Pocket PC Logo
Popular Tags
13 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iPAQ HP
  • iPAQ HP
Most Popular Question
downloaded upgraded rom
  • Computers & Internet
