20 Most Recent Sharp MX-2700N Color Copier Questions & Answers
This procedure may help, it works on older models.
Press # key
press * key
press C key
press * key
enter 16
press start key
Turn the machine off and then back on
Good luck
Sharp MX-2700N... | Answered on Dec 14, 2019
Toner cartridge CRUM error (YELLOW)
CRUM cannot be read or written.
1. Connection trouble or disconnection of the connector and the harness between the PCU and the toner cartridge. Check the connector and the harness between the PCU and the toner cartridge.
2. CRUM trouble. Replace the toner cartridge.
3. Control PWB (PCU) trouble. Replace the PCU PWB.
Sharp MX-2700N... | Answered on Aug 20, 2019
If your network is set up to DHCP your leases may have expired and your server may have given new IP Addresses to the destinations you want to send to. Check in the settings of the MFP (copier) that the IP address matches what the IP Address (check at the computer as well) on the computer is. When all else fails (including reboot of all) reinstall the software.
Sharp MX-2700N... | Answered on Mar 24, 2016
It is completely out that is why it is saying replace
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp MX-2700N... | Answered on Jan 30, 2016
might be that you are using 3rd party toner or that the machine need to be re calibrate have a tech come out and check it out
Run a gradation test, might require a tech to access service mode,
Well you could power off the machine disconnect the finsher phyiscally and electrically and then power on the machine
what is wrong with you the machine is telling you what is happening then the must be some thing wrong with you grow up ask real question on jokes
Sharp MX-2700N... | Answered on Nov 19, 2015
have you check the sensor actuates on the registration section
L4 errors relate to motors. L4-02 specifically means Paper feed motor locking trouble.
You will need to take it in for repairs.
Sharp MX-2700N... | Answered on Nov 05, 2015
Not really a problem, just information.. codes are here:
SHARP MX 2700N MAINTENANCE CODES error codes
Sharp MX-2700N... | Answered on Oct 07, 2015
HI
H5-01 means you have had five consecutive jams, it would suggest there is either something blocking the paper path, or the paper is not being picked up at all.
Try resetting the machine by the following:
Program, *, clear, *
It will then ask for a simulation code, enter 14 and press print, are you sure?, press yes. Clear all, clear all, should reboot the machine and try again.
If it continues to jam, try a different cassette.
Cheers
Andy
Sharp MX-2700N... | Answered on Apr 24, 2015
From the scan section, chose your recipient(s) first.
Then go to Image Settings > Auto/Original >
Choose 2-sided booklet or tablet, choose portrait or landscape orientation. Then scan as usual.
I believe you can also make this a default under System
Settings > [Admin Login] > Image Send Settings
Sharp MX-2700N... | Answered on Apr 10, 2015
You put your papers into the document feeder, then on the LCD screen there is a button that says 2 sided. Touch that button and select what you need. If you have a bunch of single sided pages that you want 2 sided then select 1,1-2. If you have a bunch of double sided pages that you need copied then select 2-2 and then puch the copy button.
Sharp MX-2700N Color Copier Logo
226 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
code u2 05 call service code
  • Office Equipment & Supplies
