20 Most Recent Gateway FX4710-UB003A Core 2 Quad Q9300 6GB DDR2 640GB NVIDIA GeForce 9800 GT Windows Vista... PC Desktop Questions & Answers
Your PC RAM memory is defective, replace it and your computer will boot up again.
Gateway... | Answered on Jul 21, 2014
Maybe the thumbnails on windows are disabled.
Google for it.
Gateway... | Answered on Aug 21, 2013
RAM, or random access memory, is the physical memory on the computer but only holds data while the computer is on.
The benefit of adding more RAM is that it generally makes your computer faster.
Almost all new computers recognize your RAM after you install it and restart the computer, but if yours doesn't there are a few simple things to do to get the memory recognized.
Check the type of memory you have.
Computer motherboards will work only with the type of memory they are designed for regardless if the memory fits or not.
There will be either a sticker on the memory or a listing on the packaging giving the memory type and speed.
Check the computer's or motherboard's manual for the type of memory that is compatible.
Install the memory and make sure it is tight, otherwise it may not get recognized.
The memory fits into slots on the computer's motherboard.
There are tabs on the side of the memory slots to release it.
Release the memory if it is installed and put it back in by pushing it down straight into the slot until it clicks.
Restart the computer and hit the appropriate key to enter the BIOS.
The key will be listed on the screen.
Go through the menu choices by using the arrow keys.
Look for the memory listing under hardware.
Make sure all memory listings are not listed as disabled.
If so, change them to enabled.
Choose anything listed similar to "Auto detect."
Exit the BIOS and restart the computer.
Gateway... | Answered on Jul 27, 2013
Lines on the monitor is a signal that the monitor might be bad or the video card is going bad.
Try another monitor on the computer. If you don't have one borrow one from a neighbor, friend, relative or co-worker. If the other monitor works without showing the lines, then your original monitor is bad. If the other monitors shows lines just like your original monitor then the video card is going bad.
When does this code 43 pop up? Does it give you any error message with the code?
I looked it up and i think it has to do with a usb device.
Check the links below and see if they help you.
http://pcsupport.about.com/od/errorc/a/code-43-error.htm
http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/code-43-error-on-windows-7/be1bdcca-7864-47c8-b9e0-cbc65488ba22
Gateway... | Answered on May 04, 2012
try replacing your power supply, thats prolly the problem
Gateway... | Answered on Nov 10, 2011
Contact Gateway / Acer Support for help. www.gateway.com
Gateway... | Answered on Jun 17, 2011
Please install clean Os and delete all the partition and create partition and install.
hope this helps,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Gateway... | Answered on Jan 20, 2011
Its of because the invalid keys are in ur registry that interrupted ur game path that's y its gives this error use some registry cleaner like reginout it will fix ur problem and ur games start working fine.
Gateway... | Answered on Sep 01, 2010
If you want to restore windows to when it was new, then go to start button,
all programs, accessories, system tools, system restore, check choose
a different restore point, next, now, check show all restore points.
See if the oldest restore point is good enough, it you are ok with that one
then left click on it to highlight it then click next and finish.
Gateway... | Answered on Feb 08, 2010
fmr888 is correct, if the warranty for the system is to send it to depot for repair, that is shat you should do. The system has a warranty and you should use it and have the system repaired.
Now, if after they try to repair it, if they fail to resolve the problem, then you might have grounds to request a replacement. But not until they attempt to fix the system.
Gateway... | Answered on Feb 05, 2010
Contact Gateway and have them send you a recovery disc. This might help you access the recovery partition if the recovery software was damaged somehow.
Gateway... | Answered on Oct 14, 2009
Open the folder where the files are stored.
Click on 'Tools'
Click on 'Folder Options'
Click on the 'View' tab.
Check the box that says "Do not cache thumbnails"
Click ok.
I hope that fixes it.
Gateway... | Answered on Sep 28, 2009
remove the door and put in greas
Gateway... | Answered on Sep 07, 2009
your powersource has blown out. get a replacement, only $40CAD average for repair
Gateway... | Answered on Aug 25, 2009
you dont in most cases. Install Ubunto operating system, its free only takes minutes to install, it looks just like XP or VISTA. then run your program and flash it. Google "Ubunto" or linuz download.
Gateway... | Answered on Jun 05, 2009
You need a firmware update to your DVD drive - http://support.microsoft.com/kb/930984
Gateway FX4710-UB003A Core 2 Quad Q9300 6GB DDR2 640GB NVIDIA GeForce 9800 GT Windows Vista... PC Desktop Logo
30 questions posted
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Fx Gateway
  • Fx Gateway
Most Popular Question
desk top computer fx4710 ub003a stopped
  • Computers & Internet
