20 Most Recent Gateway GT5692 Desktop Computer Questions & Answers
Open a web browser and enter IP. http://192.168.1.254/
PS. Taking a little time to post as much specific details would be helpful all around.
Gateway GT5692... | Answered on Nov 04, 2019
Reinstall windows in an new folder. Here's a link to the microsoft knowledgebase article: http://support.microsoft.com/kb/259003
Gateway GT5692... | Answered on Feb 27, 2015
There might be a short circuit in the AC Adapter or it the power cord. You should look in a manual (if available) and contact your provider for assistance.
Gateway GT5692... | Answered on Feb 07, 2014
User account control?
Google search UAC or disable user account control
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Gateway GT5692... | Answered on May 15, 2013
it will fit in same slot
Gateway GT5692... | Answered on Apr 23, 2013
Were you able to play the xbox games before on the pc?.Give me an example of the error codes.
Is flashplayer up to date?
Gateway GT5692... | Answered on Apr 14, 2013
I'm assuming that your keyboard and mouse are wireless versions. You should therefore have a wireless controller plugged into one of the USB ports, probably at the back of the PC. Try removing the wireless controller and install it in a different USB port. The Windows operating system should detect it as a new device and attempt to install the drivers automatically.
Gateway GT5692... | Answered on Dec 23, 2012
Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in facebook.com) or your preferred browser
Internet search facebook login
Once logged in in the right hand corner on the facebook homepage you will see ACCOUNT from the drop down list will be Edit friends Account settings Privacy settings Help center and Log out you could use the help center type in you problem you might have to wait a for 2/3 days for a reply due to overloading on this site also
http://www.filebuzz.com/fileinfo/87599/Facebook_Login.html
Facebook Login software is freeware specially designed for Facebook browsing. This simple application has many features for you. Application is more speeder and secures Facebook browsing than your normal...
If your Facebook profile is still unavailable after many days, then send an email to
[email protected],
[email protected] or
[email protected] and explain them the issue.
http://www.facebook.com/help/?page=121467344601554
Once you send them an email, your account will be available again soon.
Hope this helps
Gateway GT5692... | Answered on Oct 30, 2012
The light on means its getting enough power to turn on the light
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
scroll to bottom toolbar bottom of screen right click select task manager
applications you will see whats running if you see anything you dont need running select end now
also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs
not having enough computer ram can cause memory dumps
If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible
hope this helps
Gateway GT5692... | Answered on Oct 04, 2012
download a free program called ccleaner and run it.
Gateway GT5692... | Answered on Sep 29, 2012
You turned the laptop on and off and it still is asleep?
When you turned it off did the power go completely off? If not remove the power cord to make it go off.
Try booting up into safe mode and see if it goes to sleep.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity so you can view the manual later) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. Check your Power Options in the Control Panel to set your Sleep Mode and Hibernation up higher or set it to NEVER. Click Start/Control Panel and look for Power Option (it might be under System and Performance).
Below is a link to your user manual. You want to go to Pages 77 and 78 where it talks about changing the Power Plan. You want to select Change Advanced Settings as it talks about on pages 78 and you will be allowed to change the hibernate and sleep settings.
http://support.gateway.com/s/Manuals/Desktops/8512158.pdf
Gateway GT5692... | Answered on Jun 03, 2012
Try to boot up into "Safe Mode", do this by hitting the F7 key upon bootup.
A screen with a selection list should appear then use the up/down keys to highlight
the "Safe Mode" and press enter. If the computer boots up to windows then
try a system restore to an earlier date. This can be found in the "Accessories"
under "Tools". The problem could be a malware or other corruption.
It is also possible that your S.M.A.R.T. drive monitoring feature has in fact
determined that your hard drive has failed. If this so, then replace the drive
and install Gatewat recovery DVD on the new drive. You will also have allow
the updates from Microsoft as well as any other programs you had installed.
You might be able to access your files that were on the failed drive by
connecting it as a slave drive on your computer.
Gateway GT5692... | Answered on Aug 24, 2011
If your computer system goes into auto power saving mode you can get out of this state by clicking the mouse, moving the mouse, pressing enter or space. Try the wake up button if you have one on your keyboard.
You can set the setting of power saving mode by navigating to your Windows control panel and double clicking Power Options.
Under the power schemes tab select the time period to go into standby mode. Click apply and ok, when you are finished.
Take care!
damnor01
Gateway GT5692... | Answered on Jun 30, 2011
If you want to wipe it, then ignore the recovery feature. Most often, this is simply to repair an existing Windows installation. Using the recovery option will not save your programs or settings anyway. Just re-install Windows and your drivers from scratch.
Gateway GT5692... | Answered on May 05, 2011
You either have a massive mechanical failure or a virus. I have seen this caused many times before by a virus batch file opening and closing the DVD drive. You can restore the computer or bring it to someone to have it cleaned out.
Gateway GT5692... | Answered on Mar 01, 2011
Very likely not related at all. Make sure cable from monitor is securely connected to the computer. If it is, try connecting it to someone else's computer to see if it works there. If it does your computer has a problem, probably hardware, a new video card might fix that. If the monitor doesn't work on the other person's computer then the monitor will probably have to be replaced. Good luck.
Gateway GT5692... | Answered on Feb 28, 2011
if the computer refuse to defragment a partition it means that you do not have enough free space on that partition for the action ...so you need at least 15% free space ..the action to do is to delete some useless files or old ones you do not need anymore..and perform the action ..
Gateway GT5692... | Answered on Oct 01, 2010
Don't worry please just follow the easy steps and fix your problem
  • Use the defragmentation tool (defrag). A hard drive consists of hundreds of sectors which or broken up into clusters and then further into allocations. As a computer gets used the files that are accessed are sometimes not put back to the sector or allocation unit where they belong. The drive becomes “fragmented”. The defrag tool can be accessed by going to the start bar, to programs, accessories, system tools and defragmentation tool. It may take several hours to properly defrag a hard drive, but the resulting gain in speed will make this time well spent. Files will be more quickly accessed and all of the bad sectors on a disk will not contain any information on them. Hence, a user will not wait in vain for a file that is stuck on a bad part of the hard drive.
  • Use registry fix programs. The computer registry can be described as the database that contains all of the settings and options for 32 bit versions of Microsoft Windows (including Windows 95, 98, ME, NT, XP, and 2000.) It also contains all of the settings for the hardware, software, users, and preferences of the P.C. Whenever a user makes changes in the Control Panel settings, file associations, system policies, or installed software, the changes are reflected in the computers registry. Many times a registry error occurs and this causes files and data to be inaccessible. If there are numerous minor errors (which is usually the case) a registry fix program will get the data back in accessible sequence and a slow computer will be speeded up with this fix.
  • Adding more RAM (random access memory) to your system will almost always help speed up a slow computer and the act of multi-tasking will not bog down the computer as it would with a lower amount of RAM. RAM is hardware that needs to be physically added and tends to be somewhat costly. However if you plan on keeping your system for a while it is an excellent investment.
  • For faster browsing speed clear your Internet cache (temporary internet files) and delete your cookies. This causes the computer to gain speed on the Internet and the pop-ups from sites that you have been to will also be less frequent.
  • Remove unnecessary items from the start menu. To do this type “msconfig” in the “run” box and hit enter. Choose selective startup and uncheck all of the programs that you do not need to load every time you start your computer. This will make the computer start more quickly and efficiently. DO NOT uncheck items that you do not recognize. This could cause you computer to run improperly.
  • Use a browser with an integrated pop-up blocker (Firefox for example) to decrease the amount of pop-ups and increase browsing speed.
  • Constantly scan for viruses and Trojans. Trojans can be on a system for weeks even months unbeknownst to the user causing major slowdowns and file errors. Try using a specific Trojan scanner instead of the conventional virus all-purpose scanner. Many Trojans slip past the “big name” virus scanners and need to be sought out specifically to be removed.
Please rate me if this solution works for you
Thanks......Have a great time.
Gateway GT5692... | Answered on Aug 20, 2010
Gateway GT5692 Desktop Computer Logo
Popular Tags
44 questions posted
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
replace faster cpu same motherboard
  • Computers & Internet
