20 Most Recent
Gateway GT5694 Desktop Computer Questions & Answers
Gateway with 2 data ports
The "Connect monitor to alternate video port" message suggests that it is the motherboard video port. Since your computer has a video graphics card, the motherboard connections are disabled in the BIOS. (This avoids conflicts.)Many video cards have several display ports each of a different type (VGA, DVI, HDMI, DisplayPort (less likely on a low-end desktop)) . Some of these cards can drive two monitors at the same time. Look at where your current monitor is connected, then consider an adapter to connect the second monitor to that video card. (For example, a DVI to VGA adapter will let you connect a VGA monitor cable to the DVI port.) Some DVI ports will let you run two monitors from the one port with a splitter. Gateway has support documents for their computers here:
http://support.gateway.com/us/en/support/default.aspx . You'll need to use the model number and look for the User's Guide, Top Answers and support documents tabs. The only way to use the blocked port would be to enable it in the BIOS (usually press F2 on start up for Gateways). Press this key repeatedly from power on until it responds. I frequently miss the timing, just shut down and try again. However, first you would need to remove the graphics card drivers (uninstall program (Catalyst for AMD/ATI) and the drivers) from your Windows OS. Then remove the graphics card from the desktop. Since this requires opening the computer, you will need to be careful to remain grounded relative to the computer. (Use a ground strap or work carefully touching a metal surface of the case.) Please add a comment with your computer's model number and I'll be glad to give you specifics on running two monitors from your system. I hope this helps. Cindy Wells
What is this card in my GT5694 in the PCI Express slot?
Sounds like a LAN card, you know internet, should have a port that looks like a phone line or RJ-45, which is a cable line for internet.Onboard and cards for a LAN, have these lights, the link is for internet activity.There is nothing needed in a PCI slot to run a PC, the only thing would be a graph card, and that is easy to tell because it has a graph plug or your monitor is plugged into it. A VGA port.Besides this, no. But it is not slowing down the PC, or hurting anything.Do not touch it or remove it unless you power down, unplug the power, hit the power button twice and make sure the PC lights don't flash.Then touch metal just before you try and remove the card.
I am replacing my hard drive (Gateway GT5694)
The new hard drive should be set to master drive, if not just make sure the jumper is in the master slot. A small diagram should be on the hard drive. Then make sure you connect the hard drive to the end ribbon cable connector.
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do.
First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button.
Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button.
Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation.
I hope this helps!
3/14/2023 5:41:18 PM •
Gateway...
Answered
on Mar 14, 2023
I have a 2017 Gateway All in One Pentium Model zx6980 Push power button monitor comes on faintly No signal HD something. Will not boot
It sounds like there could be a few different issues going on with your computer. Here are some steps you can try to troubleshoot the problem:
- Check the connections: Make sure all cables and connections are secure and properly plugged in. This includes the power cable, monitor cable, and any other peripheral cables.
- Check the monitor: Try connecting your computer to a different monitor to see if the issue is with the monitor itself. If the other monitor works, the problem is likely with your original monitor.
- Check the hard drive: Disconnect the new SSD hard drive and try booting up the computer without it. If the computer boots up successfully, there may be an issue with the hard drive or its installation.
- Check the battery: As you mentioned, the issue could be related to the battery on the motherboard. Try replacing the battery with a new one and see if that helps.
- Try booting into safe mode: If the computer is still not booting up, try booting into safe mode by pressing the F8 key during startup. This will allow you to troubleshoot any issues with your computer's software.
If none of these steps resolve the issue, you may need to take your computer to a professional for further diagnosis and repair.
2/26/2023 7:02:04 PM •
Gateway...
Answered
on Feb 26, 2023
I need a gateway laptop recovery cd
Gateway does not provide recovery CDs for their laptops. Instead, they provide a recovery partition on the hard drive that can be used to restore the laptop to its original factory settings. To access the recovery partition, you will need to press a specific key or combination of keys when the laptop is first turned on. This key or combination of keys will vary depending on the model of laptop you have. You can find instructions for accessing the recovery partition in the laptop's user manual or on Gateway's
2/21/2023 10:42:44 PM •
Gateway...
Answered
on Feb 21, 2023
