20 Most Recent Lenovo IdeaPad Y510 Core-2 Duo: Y510 Series IdeaPad - Core-2 Duo T5750 Processor; 3072M Memory; 250G... PC Notebook Questions & Answers
Have you tried pressing the Fn + F8 keys? This combination is used to disable and enable the mouse pad.
Lenovo IdeaPad... | Answered on Sep 13, 2015
Try this....
Doubleclick on your energycut icon in tray.
Doubleclick on your power scheme that you want to change.
Lenovo IdeaPad... | Answered on Sep 07, 2015
Does you mouse have a ball? If so, it needs to have the ring that holds the ball into the bottom taken off and the tiny white nylon rollers inside the mouse need to be cleaned, I use a toothpick or a wood match stick. The rollers get lint on them, If you have an electronic ( laser) mouse ( like with a red light), it needs to be blown our with high pressure air or maybe replaced.
Be blessed.
Lenovo IdeaPad... | Answered on Aug 12, 2013
Please refer to this link to find the exact file you are looking for:
http://consumersupport.lenovo.com/ot/en/driversdownloads/drivers_list.aspx?categoryid=43
Lenovo IdeaPad... | Answered on Jul 01, 2012
go here to get your download
http://www.laptops-drivers.com/lenovo-laptop/lenovo-ideapad-y510-notebooks-driver.html
Lenovo IdeaPad... | Answered on Aug 05, 2010
try this tip, nimmiti_lava
click start > run > type regedit
click HKEY_LOCAL_MACHINE , then click SYSTEM
then click CURRENTCONTROLSET, then click CONTROL
then click CLASS, then click the folder 4D36E965
delete the LowerFilters & UpperFilters on the right side of the registry
then restart the pc
Hope this helps...
Lenovo IdeaPad... | Answered on May 08, 2010
Windows 7 is a new platform and every hardware manufacture is developing the driver suits for it.Meanwhile you will have to download the drivers directly from the chip manufacturers site e.g. for sound you can download it from http://www.realtek.com.tw/downloads/.
About the chip manufacturers you can know from the Y510 page where the drivers are there for Vista or XP.
Thanks.
Lenovo IdeaPad... | Answered on Dec 28, 2009
well I've encounter that before, ok this is what you can do..
XP installer cannot solve the problem..
try to download trial version of widows 7 installer on microsoft website, once you ave it in cd or dvd,
just put it on your cd rom drive and have it start all over again, when prompted to boot on cd, click enter
install the windows 7 directly, after clean installation, then you'll find that your laptop is ok
it is up to you if you would like to keep the windows 7 as your OS or downgrade it to vista or xp.
beware that windows 7 still have a driver issue, but it is working.
if you gonna need genuine serial key, please contact us by subscribing as a premium member and I will provide you genuine serial key
Lenovo IdeaPad... | Answered on Nov 01, 2009
Short Form (for Experts only):
Delete the file Vgraph.dll from \WINDOWS\ OR any other place resident
Long Form: (Estimated Burden: 1-5 Minutes)
STEP 1:
DELETE ALL YOUR INTERNET EXPLORER (IE) TEMP FILES AND COOKIES BEFORE YOU CONTINUE.
METHOD:
If your IE is hung up:
Click on
Start/Settings/Control Panel/Internet Options/#
If your IE is not hung up:
Click on: TOOLS/INTERNET OPTIONS/
#GENERAL TAB/TEMPORARY INTERNET FILES/DELETE COOKIES & DELETE TEMP FILES
STEP 2:
NOW UPDATE ALL Objects/Downloaded Program Files
METHOD:
#GENERAL TAB/TEMPORARY INTERNET FILES/SETTINGS/VIEW OBJECTS/ SELECT ALL, RIGHT CLICK, UPDATE
OR
WINDOWS\Downloaded Program Files SELECT ALL, RIGHT CLICK, UPDATE
Note: If update takes too long then keep in mind the ones that have been updated and skip the ones that take too long.
STEP 3:
Under IE's Manage Add-ons disable the CvgraphObj Object
Tools/Manage Add-ons (Alt+T in Internet Explorer)
Click on
Start/Settings/Control Panel/Internet Options/Programs/Manage Add-ons
Now Disable the
CvgraphObj Object
STEP 4: Restart INTERNET EXPLORER
STEP 5: SMILE :-)
If this does not work for you then read below
STEP 6: Try to find Rogue Applications that are installed as objects. Anything suspicious--> Disable it
Lenovo IdeaPad... | Answered on Sep 17, 2009
please re install the window
Lenovo IdeaPad... | Answered on Jul 24, 2009
first you have check the configuration in your device and check the Input value if your input value and service provider input value doesn't mach than you have to correct it
Lenovo IdeaPad... | Answered on Jul 06, 2009
for you have used the machine for more than 1 year then your touch pad need to be replaced however if it has happened abruptly then reinstall the touch pad drivers
Lenovo IdeaPad... | Answered on May 26, 2009
Please update the Touchpad driver from www.lenovo.com
Lenovo IdeaPad... | Answered on May 25, 2009
The issue of Error Code 0xc0000225 generally occurs when Windows cannot find the system files used for booting, boot configuration data files are being missed or corrupted while accessing any application or system files/programs.
Check The Printer's Connection
Restart Your Device
Make Sure Your Printer is Online
FULL steps in this blog- Error Code 0xc0000225
View the Original blog
Website:-
www.hptechnicalsupportphonenumber.com/blog/fix-hp-stream-notebook-error-code-0xc0000225/
Lenovo IdeaPad... | Answered on Apr 07, 2020
If you bought the Lenovo at a local dealer, take it back to them. If you bought it through an online dealer, I recommend you track down Lenovo customer support.
Lenovo IdeaPad... | Answered on Sep 05, 2019
really why not ask the game maker directly for help with your w10.
here they are right>?
https://www.mygames.com/
so what do THEY say , it is there code, running.
does Tetris fail or just your games, unnamed,
this maker is bad company they take over your PC
why run this crappp? it takes over your browser,
and more, and is bad.
the do not even have minimum system requirement there.
nor support. avoid like the Plague.
Lenovo IdeaPad... | Answered on Jun 30, 2019
Lenovo IdeaPad Y510 Core-2 Duo: Y510 Series IdeaPad - Core-2 Duo T5750 Processor; 3072M Memory; 250G...  PC Notebook Logo
Popular Tags
21 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
lenovo touch pad not working properly
  • Computers & Internet
