20 Most Recent Fujitsu LifeBook A6110 PC Notebook Questions & Answers
Webcams are either started by their specific programs or they are used by the IMs that you use. To use with the IM you must configure the IM (Skype, Yahoo Messenger, MSN or whatever you have) from their respective Tools->Options->Video to use this webcam as the default camera. Also in the Audio option you must use the built in mic of this laptop as the default mic.
Once you have done this then everytime you use the IM for video talk or just talk then the webcam and mic or just the mic will be used automatically.
While if you use the specific program to use the webcam then the webcam and mic will be used without any configuration. However, you must configure things like mirroring and colors etc so that when you move to the left the video should show you moving left and not otherwise.
Happy Holidays.
Fujitsu LifeBook... • Answered on Jul 22, 2014
you need to download a program call you cam 4 and install it
Fujitsu LifeBook... • Answered on Jun 25, 2013
do a system restore.. it will not erase anything.. it only restores settings.. start>all programs>accessories>system tools>system restore... (if you are running windows 7 click next then check the box "show more restore points") choose a date before the problem.. if that doesn't work re-install the video drivers from the manufacturer website. good luck
Fujitsu LifeBook... • Answered on Jun 17, 2013
If the BIOS does not list the USB devise in the Boot start up then You cannot boot up the laptop with an USB device.It maybe possible with a BIOS upgrade, check the Fujitsu WEB site.
Fujitsu LifeBook... • Answered on May 06, 2013
You need to access the camera from the ArcSoft WebCam Companion application. If you do not have it installed, you can download it from your manufacturers website. Once installed, it will work fine.
Fujitsu LifeBook... • Answered on May 12, 2012
You will need a programme that is able to read an image source on your laptop.
Debut is free and a compact software package that reads any image source connected to your computer.
http://debut-video-capture.en.softonic.com/
Fujitsu LifeBook... • Answered on Jan 09, 2011
This could happen when the RAM contact is not proper, may be due to dust. Remove the memory modules from DIMM slot, clean it (no moisture please) and reinsert it. This could mostly solve your issue.
Please come back and rate my solution if it turns helpful for you or also if you need more clarifications. Thnx
Fujitsu LifeBook... • Answered on Apr 01, 2010
Call 1-800-fujitsu option 3. It is free!
Fujitsu LifeBook... • Answered on Mar 10, 2009
Try a hard shutdown if the volume is up.
Fujitsu LifeBook... • Answered on May 04, 2019
your problem could be that the hard drive is broken, perhaps with some tool to repair hard disks the problem. test starting for example hiren boot from a memory or cd and see if it recognizes the hdd, if so you can pass some repair tool
Fujitsu LifeBook... • Answered on Nov 21, 2017
remove the bios password by removing the cmos battery, removing the jumper from the pins right next to the battery, marked something like pswd, plugging it in and hitting the start button.Before you open the case, unplug, remove the bettery, then hold the start button to get rid of any energy.
Fujitsu LifeBook... • Answered on May 14, 2016
please mention the laptop model
Fujitsu LifeBook... • Answered on Apr 29, 2016
Sounds like liquid may have been spilled on the keyboard. Plug in an external usb keyboard and check if it works. If so, you will need to buy a replacement keyboard and swap it out, best cheap from Ebay.
Fujitsu LifeBook... • Answered on Dec 06, 2015
Fujitsu LifeBook A6110  PC Notebook Logo
42 questions posted
Top Fujitsu Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Carlo Barzo
Carlo Barzo
Davit Mamyan
Davit Mamyan
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LifeBook Fujitsu
  • LifeBook Fujitsu
Most Popular Question
enable webcam
  • Computers & Internet
