20 Most Recent NEC NDT44 DVD Player/VCR Questions & Answers
on your remote down on the left hand side at the bottom of it its the second last button called c.lock its right above easy rpt press n hold till the little red key flashes and disapears off your unit !
NEC NDT44 DVD... • Answered on Feb 13, 2020
First check if the cables are properly connected to the television, then ensure the problem is not from the television by hooking up another player to it to see if it plays fine with good picture.
If it does the same, then you need to know that the problem is from the television and not your player, but if the image is clear, then you need to know the problem is from the player.
Such problem might be caused by the AV port or from the main board.
Try to assess the main panel to see if it has some lead melted on it causing there to be a bridge of two capacitors together, also you can check for bad capacitors. If you detect any of these to be the fault, then correct bridging leads by using a soldering iron to break off the bridge of lead, then melt off the bad capacitor and replace it with a new one if that seems to be the problem.
Take care and good luck
NEC NDT44 DVD... • Answered on Oct 31, 2010
It sounds like the laser or another mechanism involved with reading the dvd's is defective I highly recommend you have the unit serviced under warranty if it is only 4 months old. contact the corresponding nec to where you live at this link and inquire about repair/replacement:
http://www.nec.com/global/support/contact/index.html
Thank you,
Lee
NEC NDT44 DVD... • Answered on Nov 18, 2009
http://static.fixya.com/Manuals/N/NEC/NDT44_DVD_Pl_A99F03B9FF64B4BBCEA7CE8E733398F8.pd
The manual is above.
If that doesn`t help have a read of the following
http://www.ehow.com/how_2036282_remove-dvd-player.html
NEC NDT44 DVD... • Answered on Oct 18, 2009
You need to turn the power on, enter your DVD or Video Cassette, then press the triangle symbol which will play your DVD or Video. Cheers, eiger3790.
NEC NDT44 DVD... • Answered on Jul 28, 2009
Your DVD is likely in the wrong format for your DVD player to read. Try downloading the DVDs in another format or convert from DivX to DVD. Cheers, eiger3790.
Depending on the model of you hardware, you can generally
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Cheers, eiger3970.
CLICK HERE for your product manual in PDF format.
Thanks for using FixYa!!
NEC NDT44 DVD... • Answered on Jun 10, 2009
Go the co.;s web site go to product support. find you model and then download a manual for free. pdif file use Adobe to read. that's it DFD
NEC NDT44 DVD... • Answered on Apr 11, 2009
andrew answered this yesterday and someone deleted it. its to keep the tape from freespooling
NEC Televison &... • Answered on May 01, 2021
Try going to the NEC website and download a user manual >>> http://www.generalmanual.com/Televisions/NEC-NLT-32XT1-LCD-Television.htm <<< That would I think, have the instructions about doing just that. Regards Geoff
NEC Televison &... • Answered on Jan 07, 2020
NEC NDT44 DVD Player/VCR Logo
Popular Tags
25 questions posted
Top NEC Televison & Video Experts
Richard Lilja
Richard Lilja
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • NEC Televison & Video
Most Popular Question
nec ndt 40 dvd vcr turn off child lock
  • Televison & Video
