20 Most Recent
Nyko Charge Station 360 For Xbox 360 Questions & Answers
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Alkalines won't work in my 360 controller.
there are units designed to run on rechargeable batteries and some that run on alkaline batteries
the difference is the current draw required
alkaline batteries have a high discharge rate available but for short duration while the others have a smaller discharge rate but over a longer period of time
you should only use the type of batteries recommended for the unit
Hi. We have a NYKO
Hello
The red light means its charging, then when its done
charging it turns green briefly then the lights and charger turn off and
the controller is ready.
Please rate.
Can't connect xbox controller with NYKO batteries.
I had the same problem, asked Nyko's support department about it, and they told me that Microsoft updated their controllers at some point in the past, and this update rendered the version of battery pack I had useless. There is an updated version, but you will have to ship your old one back to Nyko and wait a few weeks. Hope this helps.
