20 Most Recent LG LH-T754 Theater System Questions & Answers
I lost the remote for
If u are trying to change the input from dvd to usb or the other inputs. All you have to do is hold down the play button on the front of the dvd home theater system until it starts to flash then press it again and keep pressing until u find the input u are looking for. It will rotate thru all inputs even the ipod input.
8/21/2018 10:14:57 PM • LG LH-T754... • Answered on Aug 21, 2018
0answers
LG LHT754 stuck on dvd function and won't change input
Hold down "2" on the remote simultaneous to "stop" on the receiver. In a couple of seconds you will see something appear on the display. OPO-63? Anyway, repeat the process again when you see that. The system will reset. This will also take care of the inability to switch to AUX or Ipod.
9/8/2014 12:30:46 AM • LG LH-T754... • Answered on Sep 08, 2014
2answers
LG LHT754 is frozen in aux mode. I tried holding
Unplug the unit for 60 minutes, when you plug it in hold the power button for 5-10 sec which will do a hard reset. This will reset the processor and hopefully the unit will operate normally.
9/8/2014 12:23:27 AM • LG LH-T754... • Answered on Sep 08, 2014
2answers
I have a lhb975 5.1
You've probably found an answer to this already but just in case...
You're most likely going to have to return the unit -- just receiver and subwoofer in my case as the sub was the only speaker not synching up.
Rather than dealing with their useless "Chat" web support, I would HIGHLY recommend calling their support # to get an RMA. Then request they EMAIL the RMA forms to you rather than snail mail. Also, make sure they have your correct name and info in their ridiculously poor customer database. They had my LHB975 serial # associated with some other person's name and address!! It literally took weeks and at least 6 calls to get it straightened out. Never again....if it dies again, it goes straight in the trash.
3/11/2012 7:33:58 AM • LG LH-T754... • Answered on Mar 11, 2012
0answers
Aux not working
Be the first to answer 1/27/2012 9:46:14 PM • LG LH-T754... • Posted on Jan 27, 2012Be the first to answer
I have a LG LH-T754
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
3/2/2011 5:45:31 PM • LG LH-T754... • Answered on Mar 02, 2011
I cannot get a sound out of the speakers also
It sounds like it isn't fully powering on or the logic is hosed up.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
1/26/2011 10:27:58 AM • LG LH-T754... • Answered on Jan 26, 2011
0answers
SE LO PRENDE Y
Be the first to answer 12/30/2010 5:58:05 PM • LG LH-T754... • Posted on Dec 30, 2010Be the first to answer
LG Surround Sound Troubleshooting
I have a lg dvd/surruond sound and the remote suddenly stopped working. I bought a new lg riginal remote but still nothing, any thoughts?
12/16/2010 1:15:07 PM • LG LH-T754... • Answered on Dec 16, 2010
0answers
LG HT752TH Surround sound system rear x2 and
They will work only if the source signal is itself 5.1. If it's stereo then you must convert it to 5.1 using the Virtual sound setting (press VSM to access it and select 5.1).
9/2/2010 9:54:35 AM • LG LH-T754... • Answered on Sep 02, 2010
My home theater system plays cds but will not play
There is something wrong with the DVD drive assembly inside. If you're brave, take it apart and check on what is making the noise. Also, try using a q-tip to clean the laser head if it's accessible.
If that doesn't help, it's time for a new DVD player.
This is why I always recommend people buy a home theater system without a DVD player built in. The DVD player is the weakest link, and stand alone DVD players can be purchased for as little as $25 depending on if you want upconversion or not.
If you cannot get the DVD player working in your surround system, just replace it with a stand alone DVD player, if you can, check to make sure there are audio inputs on the back of the receiver. If there are no audio inputs on the receiver, you will have to get the entire surround system replaced. If so, purchase a separate DVD player and surround system.
1/26/2010 7:49:25 PM • LG LH-T754... • Answered on Jan 26, 2010
Hey, on my LG Blu-ray I have with surround sound,
You already said the Blu-Ray is working, so let's assume it's ok. Other source(s) don't produce surround so that leaves it (them) orthe one place they all come together - your receiver / theater system. Multichannel sound will only come from properly connected digital sources. Is that the case?
1/21/2010 4:50:15 AM • LG LH-T754... • Answered on Jan 21, 2010
When watching a DVD in surround sound movie mode
FIRST- double check that the center channel is hooked up in the center channel connection. we have all made this mistake. second if you are watching a movie through a dvd or bluray player be sure that both your audio L/R rca's or hdmi cable's are plugged in. I do not know if your are on cable or satellite? Double check the connections. Be sure that the that if your can select your sound preference turn it to 5.1 surround or matrix. hope this helps
1/11/2010 2:21:11 AM • LG LH-T754... • Answered on Jan 11, 2010
Hooking up a Samsung Blu Ray to an LG Home Theatre & Toshiba TV
I used to have a setup pretty much exactly how yours is hooked up ( Different brand name equip. but basically the same setup) and I had to enter the custom setup screen for my home theater system and there was a setting there that allows you to choose between using a digital optical cable or a digital coaxial cable. I don't know if this is the exact same thing you have but it's worth a try because it sounds like it has to be a setting because like you say sound comes out of the t.v. ( and yes that is not acceptable) so you almost have got it. Keep at it, you can't really mess anything up by hooking up something wrong, it just won't work. Good Luck.
12/20/2009 9:37:02 PM • LG LH-T754... • Answered on Dec 20, 2009
LG LH-T754 Theater System Logo
Popular Tags
26 questions posted
Top LG Audio Players & Recorders Experts
 Francisco Mauricio...
tina gallow
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • LG Audio Players & Recorders
Most Popular Question
lhb975 5 1
  • Audio Players & Recorders
