20 Most Recent Epiphone Les Paul Studio Electric Guitar Questions & Answers
Here are links to a standard LP wiring diagram and a LP Jr. wiring diagram. Absolutley free at stewmac.com
http://www.stewmac.com/freeinfo/Electronics/Wiring_diagrams/i-1217.html
Epiphone Les... | Answered on May 14, 2020
Your guitar was made in
Indonesia
February 2011
Production Number: 15803
Epiphone Les... | Answered on Mar 22, 2015
google your problem. i have found scematics on everything. i'm currenly changing out the pickups on my les paul, and saw the diagram on your soldering setup. i've done these myself. i was a little worried at first, but it turned out to be pretty easy. good luck, scott
Epiphone Les... | Answered on Feb 16, 2015
These are not user serviceable problems. Take it to a repair shop.
Epiphone Les... | Answered on Jan 02, 2015
There are lots of online videos to watch to do this, that would be more helpful than reading how to do it.
Epiphone Les... | Answered on Nov 26, 2014
Depending on condition and if all parts are original or not, there are variables. If all original, 125 is less than half of what a new one costs.
Epiphone is a budget conscious gibson. And probably not made in the USA.
1957 - Gibson's parent company, CMI, buys Epiphone for $20,000, originally intending to harness its upright bass operation, but ultimately reviving the Epiphone name on guitars. A full line of newly designed acoustics and electrics is unveiled in 1958, and two years later Epiphone production moves into Gibson's factory in Kalamazoo, Michigan.
1970 - In the face of foreign competition, Epiphone production is moved to Japan. Through the 1970s and early '80s, the Epiphone line has little continuity, although it maintains respect as a quality import brand.
1983 - Epiphone production is moved to Korea.
1986 - Henry Juszkiewicz, David Berryman and Gary Zebrowski acquire Epiphone and Gibson. The Epi line is soon expanded to include traditional models like the Sheraton, Emperor and Howard Roberts, along with Epi versions of Gibson classics like the Les Paul, Flying V and Explorer.
http://www.epiphone.com/history.asp
Epiphone Les... | Answered on Oct 29, 2014
Here is the link to a generic one: http://www.epiphone.com/images/EpiOwnrsManul.pdf
Epiphone Les... | Answered on Oct 20, 2014
Not on all the guitars. My advice is to play the one you are planning on purchasing before buying it.
Epiphone Les... | Answered on May 04, 2014
Yes, the pickups can be changed.
However; In my opinion this is not worth it. Pick up a pair of aftermarket pickups for a better sound that will fit your playing style.
-Sheeves
Epiphone Les... | Answered on Apr 19, 2014
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Epiphone Les... | Answered on Dec 29, 2013
Could you please be more specific? I'm not sure if you're looking for a wiring diagram (if so, I have one posted below), or if you're having a problem with grounding or other wiring issues.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=passive_soapbar
The above link is a wiring diagram for bass guitars that closely match the one you are asking about.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Epiphone Les... | Answered on Oct 22, 2013
Or a bad solder connection on the ground wire on the jack, or shell/sheild on the guitar.
Here is the list you seek.
http://www.gibson.com/en-us/Support/TechSupport/Wiring Diagrams/
Epiphone Les... | Answered on Mar 08, 2013
A buzz on one string is not due to a pickup fault. It's rather a too low string height at the nut or a string slot that is either too wide or has too deep of an angle towards the tuner. It could however be that you had the pickup too close to the high E string creating excessive string pull.
Epiphone Les... | Answered on Jul 14, 2012
This is a common problem... Make sure your amp is plugged into a three wire grounded receptacle. Keep the guitar away from magnetic fields of transformers in amps and effects units. Make sure you have a high quality guitar cable.
Epiphone Les... | Answered on Sep 07, 2011
Amazing guitar!
Unfortunately, I have not been able to find the specialized plug you need. Being 1 out of less than 400, it is doubtful that they are still being made. However; any decent music shop will be able to repair your old plug.
Epiphone Les... | Answered on Mar 03, 2011
I have a Burns Sonic 1962. It has a complex "quirky" parallel/series wiring circuit with 3 pots, 2 switches and 2 Burns Tri-Sonic pickups. 2b4fdbd.jpg
Epiphone Les... | Answered on Jul 31, 2010
if the problem is only on the neck position it would seem that the switch or the pick up wiring is faulty. a little bit of WD40 on the selector switch will sort if the swtch is gone ...if you take the switch out and check the solder on the connections at the rear of the switch you may see the wire loose or solder point faulty.. just a dab with a solder iron should sort here.. you may need to resolder the connection.
Epiphone Les... | Answered on Jul 20, 2010
Epiphone Les Paul Studio Electric Guitar Logo
39 questions posted
Top Epiphone Music Experts
Robert Graf
Harrie
Marvin
Marvin
Are you an Epiphone Music Expert? Answer questions, earn points and help others
View Most Popular
Epiphone Music
  • Epiphone Music
Most Popular Question
get buzz out high e string epiphone les
  • Music
