20 Most Recent Panasonic NI-A57SR Iron with Auto Shut-off Questions & Answers
Iron is out of order
an appliance repair center could probably fix it but you have to consider the cost against a new iron mostly it is more costly to repair than to fix
10/19/2017 6:11:06 AM • Panasonic... • Answered on Oct 19, 2017
My iron is not warming up any more what can i do?
A. Check the wire connections. If so, tighteing or chaning the cord with do . B. Thermostat migh got suck, if so, inspection of it will show and you need to gently sand the contact point. Or worst case senario, the heating element (coil) inside the heating plate might have been burnt, is this is the case, the iron is toast.
7/23/2014 3:22:54 PM • Panasonic... • Answered on Jul 23, 2014
0answers
Iron won't heat up.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
7/14/2010 2:24:27 AM • Panasonic... • Answered on Jul 14, 2010
Panasonic iron NI-A56NR wont turn on
first test your heating element to see if it is working.
You can by pass the control module by removing it from the line. Just disconnect all wires that goes to the module and put aside, then, connect back lead to the far right connection and white wire to the third connection from the left. Be careful playing with electricity is hazardous to yout health if you don't know what you are doing.
8/20/2009 6:06:01 PM • Panasonic... • Answered on Aug 20, 2009
NI-A57SR steam Iron suddenly not functioning
I had the same problem, when I took it apart, I noticed the theromstat points needed sanding. Just a reminder, make sure to write down the order of wire leads before disconnecting. By the way to test if the heating element is working connect white lead to the second connection from the left and black lead to the far right. Place your iron flat down on a wet cloth ( so that you won't burn your surface). You can also use an electrical tester. If heating element does not work though, it is time to buy a new iron.
8/20/2009 5:57:55 PM • Panasonic... • Answered on Aug 20, 2009
Wiring digram for Panasonic NI-A57SR Iron
Same issue i believe
with metal part laying flat (ironing position) and looking at bottom side, from the left to the right - white & blue leads, lamp(resistor lead), red then both black leads and other end of lamp.
im guessing the themal fuse is the lamp? what is the PN where can i get it.
i had a small shere fall out of the unit, besides the positioning switch where else would this be located?
Thanks
4/6/2009 12:04:11 AM • Panasonic... • Answered on Apr 06, 2009
Panasonic Cordless 360 Freestyle iron NI-QL1000 steams when NO STEAM button selected.
The feed valve is possibly stuck with build up from the water. Try using distilled venegar to clear out the chalk deposits.
1/26/2024 9:07:53 AM • Panasonic Irons • Answered on Jan 26, 2024
Panasonic iron stop working
This Happens sometimes, because of overheating, which may damage circuit board and your wire may get melt. Do check your circuit board, and your power wire it may get overheat. In case if you want to purchase other Steam iron do check:- http://10lots.com/best-steam-irons/ 8 Best Steam Irons for your Cloths 2018 10 Lots
11/19/2018 6:18:50 AM • Panasonic Irons • Answered on Nov 19, 2018
Panasonic steam iron NI-L70SR repair
hope this helps you: http://www.theironingroom.com/help-my-iron-is-leaking-water/
11/19/2018 6:14:56 AM • Panasonic Irons • Answered on Nov 19, 2018
My panasonic NI22AWTXJ iron is not powering
Get a multimeter. Check that the fuse is OK. If it is ok, open the cover at the back of the iron. Plug in the iron. Be careful not to get electrocuted. Check that the cables from the socket on the wall have power. place the leads of the multimeter on the live and neutral and check for 240V or 110v depending on your country. If no power here cable could have a problem. If there is power here, turn of power and unplug socket. open top cover, you will see the heating element. Check for continuity between the ends of the element, If no continuity the element is dead and you need to buy a new iron. If it has continuity then check continuity of other components connected in series with the element. Some models a limit thermostat to prevent the iron from over heating. This looks like a small resistor about one centimeter long, if it has no continuity, cut it off and bypass it. It is a safety device that fails when it senses high temperatures in case the main control thermostat fails. If you can find a replacement replace it, if you cant find a replacement, you can use it and hope the main thermostat does not fail.
6/22/2017 5:53:01 PM • Panasonic Irons • Answered on Jun 22, 2017
How do i increase the iron heating temperature (thermostat) in Panasonic Electric Iron NI-22AWJ
Check the voltage at your power point, irons draw a lot of power. most irons have a temp setting switch cool med hot . If this a new iron return for service.
2/18/2015 9:49:14 AM • Panasonic Irons • Answered on Feb 18, 2015
0answers
0answers
0answers
Panasonic NI-A57SR Iron with Auto Shut-off Logo
Popular Tags
13 questions posted
Top Panasonic Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
View Most Popular
Panasonic Irons
  • Panasonic Irons
Most Popular Question
wiring digram panasonic ni a57sr iron
  • Irons
