20 Most Recent Eagle Fishmark 320 Portable Fishfinder Questions & Answers
try hitting the on and off button it should fix it that is your lite skle and britness
Eagle Fishmark... | Answered on Apr 07, 2017
Same problem any ideas????
Eagle Fishmark... | Answered on May 08, 2015
Think of where the transducer is fitted on your boat . As turbulence is the only problem you need to worry about. It needs too be on the transom but in between the lower 2 chines
Eagle Fishmark... | Answered on Sep 05, 2014
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Eagle Fishmark... | Answered on Jul 30, 2014
sounds to me you have a bad keyboard if so two things repair shop or time for a new one
Eagle Fishmark... | Answered on Dec 19, 2013
Eagle Fishmark 320 Portable Fishfinder Logo
Popular Tags
59 questions posted
Top Eagle Boating Experts
Michael Thomas
Michael Thomas
Mike
ray gallant
Are you an Eagle Boating Expert? Answer questions, earn points and help others
View Most Popular
Eagle Boating
  • Eagle Boating
Most Popular Question
sonar not appear work not picking up
  • Boating
