20 Most Recent
Swann Communications Swann S243 16u 11111 16 Channel Digital Video Recorder Questions & Answers
I have only started using the disks on this
as its the problem of the software through which the disc is made.and also the lens in the unit is creating the problem.check out the same in any other unit.this will not happen.
2/28/2009 1:11:00 PM •
Swann...
Answered
on Feb 28, 2009
Why does my Swann have no display?
If you checked all cable connections and made sure you monitor is set to the right input and working properly, if the dvr has multiple outputs try them all first. If none of that works it maybe the the video card on your unit is bad and may need replaced. Swann dvrs typically only last a couple years because the are garbage.
9/24/2022 1:04:50 AM •
Swann...
Answered
on Sep 24, 2022
Three cameras don't work anymore why?
try swappig the power supplys around from one that u know does still work , also ck your wires , if any run outside even for a little bit insects and animals can nibble I\on wires(they love the taste of em) and ruin cables
then I\using a spare camera go to each location and swap that around have helper to look for picture
3/18/2016 1:21:23 AM •
Swann...
Answered
on Mar 18, 2016
How do I connect my camera up using cat5 cable
Please give the Model no. of the Camera.
generally if it is an IP Camera it can be connected with a CAT5 Cable to a computer.
If it is a non-IP Camera it can be connected with a Coax Cable to a Monitor.
11/5/2014 12:53:51 PM •
Swann...
Answered
on Nov 05, 2014
