20 Most Recent Sony HVR-M35U Camcorder Questions & Answers
manual
Sony hvr-m35u deck wont turn
There is ether a problem with the power button or there is a brake in the circuit. Meaning power isn't being directed properly. Etherway you'll have to open it up. If it all looks ok check the resistors, transistors, and copasitors on the board. If they look ok poke around with a a curent tester (a screw driver with an LED insid, lights up where there's power) to see where where you're not getting any current. Once you locate where the problem is you can figure out what's wrong. Maibe some on put in a wrong transistor or something, maibe it's the wrong way. You may be able to get some schematics from the manufacturers website. It might help, but you may not even need them. If you do get them you can mach them up and see where the problem is.
9/7/2011 5:48:51 PM • Sony HVR-M35U... • Answered on Sep 07, 2011
Touchscreen
First and foremost shut down the device. Remove the battery if possible for 1 minute. Then restart/power up device. If still no luck or response. Go into the setting and look for the reset to default setting if there is no option for touch screen controls. Best of luck
4/20/2014 6:15:44 PM • Sony HVR Video... • Answered on Apr 20, 2014
0answers
0answers
I have a digital sony handycam model DCR-SR32. I did'nt use it for a couple of years. Before 2 days I charged it but the LCD monitor is red. I can't see anything crearly.
This machine dates back to 2007. I suspect most of the organic electrolytic capacitors are either leaky or short circuit and there are many. A Sony Service Centre may be able to repair it for you.
3/30/2024 8:11:57 AM • Sony Video... • Answered on Mar 30, 2024
Sony Handycam DCR-SR20. How to resolve HDD format error on it please?
An HDD FORMAT ERROR appears on the camera LCD or ...
Sony https://www.sony.com > electronics > support > articles Mar 30, 2021 - This error may occur if data becomes corrupt on the camera hard disk drive. To resolve this issue, it will be necessary to format the hard ...
E 31:00 HDD Format Error
Sony https://us.community.sony.com > question > e-3100-hd... Jun 6, 2013 - Perform a power reset on the camcorder. Turn off the camcorder. Remove the battery and disconnect the AC power adapter for 60 seconds. Insert ... ..
3/13/2024 5:39:21 PM • Sony Video... • Answered on Mar 13, 2024
I have a Sony CCD-F77 Camcorder and each time I put one of my tapes in I get a blinking signal to change the tape.
That means the mechanism is either jammed or there is no control. Due to its age it may be a problem to get it going again due to leaking capacitors from lack of use or age.
2/11/2024 8:27:21 PM • Sony Video... • Answered on Feb 11, 2024
Sony HVR-Z1E/ZIPThe cassette goes down if empty but won't move with a tape in?
The heads in your cassette might either be misaligned or dirty or need to be replaced.
6/15/2023 6:26:04 AM • Sony Video... • Answered on Jun 15, 2023
Sony Handycam CCD TRV57. The tape door closes halfway through?
It needs servicing at a Sony Service Centre. You can't fix electronics and servos at home unless you have equipment. There is a video here, because it in a known issue.
4/1/2023 5:25:17 PM • Sony Video... • Answered on Apr 01, 2023
Sony DCR IP1E screen black
Replacing the flex cable on a camcorder can be a delicate and complex process, as it requires disassembling the device and accessing its internal components. Here are some general steps that you can follow:
  1. Turn off the camcorder and remove the battery.
  2. Locate the screws or clips that hold the casing of the camcorder in place. Depending on the model, these may be on the bottom, sides, or back of the device.
  3. Carefully remove the casing and set it aside.
  4. Locate the flex cable that connects the LCD screen to the circuit board. It may be taped or clipped in place.
  5. Gently disconnect the flex cable from the circuit board and LCD screen. Take note of how it is connected so that you can reattach the new flex cable correctly.
  6. Install the new flex cable in the same position and orientation as the old one.
  7. Reconnect the flex cable to the circuit board and LCD screen.
  8. Replace the casing of the camcorder and secure it with screws or clips.
  9. Reinsert the battery and turn on the camcorder to test the LCD screen.
It's important to note that the specific steps and tools required for this process can vary depending on the make and model of your camcorder. Additionally, if you're not familiar with electronics repair, it's generally recommended to have a professional technician perform the repair to avoid damaging the device or injuring yourself.
3/18/2023 8:19:11 PM • Sony Video... • Answered on Mar 18, 2023
I have a sony dcr-dvd108. Can I get some help?
It sounds like your Sony DCR-DVD108 camcorder may have a problem with the battery or the power connection. For the battery issue, you can try replacing the battery with a new one that is compatible with your camcorder. The Sony NP-FP50 or NP-FP70 are compatible batteries for your DCR-DVD108. You can purchase them online or from a camera store. As for the "Movie Disabled" message, it may be caused by the type of disc you are using. The Sony DCR-DVD108 camcorder is compatible with DVD-R and DVD-RW discs, but it may not be compatible with all brands of discs. You may need to try using a different brand of disc to see if that resolves the issue. Additionally, make sure that the camcorder is set to the correct recording mode, such as video mode, and that there is enough space on the disc to record the video. If none of these solutions work, there may be a problem with the camcorder itself, and it may need to be repaired or replaced.
3/18/2023 8:16:49 PM • Sony Video... • Answered on Mar 18, 2023
How do you turn off timestamps on a Sony EV-S1500 tape deck?
  1. Press the
  2. Use the arrow keys
  3. Select "Display" from the setup menu
  4. Use the arrow keys to navigate to "Time Code" and select "Off" to turn off the timestamps.
  5. Press "Menu" again to exit the setup menu.
If you don't have the original remote control for the tape deck, you may need to purchase a universal remote or a replacement remote that is compatible with the EV-S1500 in order to access the menu settings.
2/25/2023 4:56:57 AM • Sony Video... • Answered on Feb 25, 2023
2answers
Question about Sony Handycam CCD-TRV85
The CR2025 is to hold memory, but it may also run the operating system memory. All the batteries need to be good. Also try cleaning the main battery contacts and those inside the camera. Check that there is power coming out of the mains adapter and the level battery power using a multimeter. After 10 years the battery will likely be defective.
2/18/2023 1:27:49 PM • Sony Video... • Answered on Feb 18, 2023
Sony HVR-M35U Camcorder Logo
3 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
HVR Sony
  • HVR Sony
Most Popular Question
sony hvr m35u deck wont turn
  • Video Cameras
