20 Most Recent Kenmore Bagless Upright VacuumVacuum Questions & Answers
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Kenmore Bagless... | Answered on Mar 21, 2012
I advised the customer of part number LIT4370069, which costs $9.99 at searspartsdirect.com. T customer advised me that he needed a service manual and troubleshooting because he is not getting any suction. The customer is going to try and get assistance from another expert.
Kenmore Bagless... | Answered on Sep 11, 2011
It might sound very easy , but lack of power is usually the cause of a vacuum cleaner that is not working . Check that the vacuum cleaner is plugged into a working power outlet and that fuses and breakers don't need resetting. An activated thermal cut-out due to a blockage is the next most likely cause of the problem.
Tripped Circuit Breaker/ Blown Fuse
Check service panel for tripped breakers/blown fuses. If breaker is tripped, reset it. If fuse is blown, replace it. If vacuum cleaner is plugged in, make sure that the power button is in the off position before having to reset the breaker/changing fuse.
Kenmore Vacuums | Answered on Sep 06, 2020
I just tried this trick from an Amazon review answer and it worked! I just turned the handle upset down, pressed the wand release button while the handle was in that position, and voila! The attachment came right out. Here's the Amazon quote I found via Google:
"Unplug the vacuum and remove the wand. If you cannot get your wand to release, try turning the handle over, and using gravity to allow the wand release switch to fall while you depress the wand release button and jiggle the wand in and out."
Kenmore Vacuums | Answered on Apr 26, 2020
Have you checked the belt? The rollers are usually attached to the
belt
Kenmore Vacuums | Answered on Jan 05, 2020
I don't have one of these, but is it possible that the new, clean bag has not been installed properly or the cover is not completely in place? Just some things to double check. If all else fails, I suggest calling the manufacturer. (Kenmore is owned by Sears)
Kenmore Vacuums | Answered on Aug 10, 2019
I saw a number of fraudulent web sites pretending to have the manual when I performed a Google internet search.
Please contact Sears to request assistance so you are not deceived.
https://www.searspartsdirect.com/search?q=385-15752090
Kenmore Vacuums | Answered on Apr 05, 2019
Kenmore Bagless Upright VacuumVacuum Logo
5 questions posted
Top Kenmore Vacuums Experts
Marvin
Marvin
jdthefixer
Mike
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Vacuums
  • Kenmore Vacuums
Most Popular Question
kenmore vacuum cleaner 175 3866180 bags
  • Vacuums
