20 Most Recent
Jl Audio 12W1v2-4 Car Subwoofer Questions & Answers
I have 2 of these brand new in a ported box in my
this could be your connection to the amp .make sure the positive leads from the sub are on the positive terminals on the amp .first try one sub alone and then connect the other one .with the second one try swaping the terminals but if your using quality products you woudnt have to just connect the leads to the terminals the belong to .positive on positive and negative on negative
4/21/2010 2:11:50 PM •
Jl Audio...
Answered
on Apr 21, 2010
When i turn my system up past thirty my amp shuts
Key things to check.
1. Make sure you have a good power and ground. Make sure you have a large enough power cable(4 gauge is a good start). The ground should always be attached to bare metal(remove paint from contact area).
2. Ensure your amps crossover is set to low pass and at about 80hz. Turn any bass boost off, and start with low gain.
3.Your enclosure should be 1.25 cu sealed, or 1.75cu ported. If you are too far off these numbers it can cause distortion and clipping.
4. For the single woofer your best amp solution would be a 300 RMS 2ch bridged to 4 OHMs. As long as you're running the sub at 4OHMs you shouldn't have a problem. Under-powering can be worse than overpowering.
5.If your head unit has high and low pass crossovers, set your low pass at 80hz as well. If the head unit doesn't have crossovers, then turn your EQ to flat.
If none of this helps, it could just be the amp.
Hopefully it helps, Plz Vote & Rate
3/15/2010 8:41:43 PM •
Jl Audio...
Answered
on Mar 15, 2010
