20 Most Recent
Samsung 943NW Monitor Questions & Answers
Hello, I have a samsung
If the monitor is completely dead, then is sounds like the power supply board has failed. Sometimes it an easy fix, by replacing a fuse. Most LCD monitors do hav a fuse, the only way to know for sure is to open the case and troubleshoot the power supply.
No display except in BIOS SETUP
my monitor 943NW if power on the blue led light on normally,but no picture or blue colour display,please help me to solution,tanks.
Picture sudenly moved down, and
Press Menu misvoda, the button on the monitor.
Then press the arrow keys to set the Left-Right size shown by the picture
Press the select key when the option is highlighted.
Do the same with the move option and/or Up-Down size shown by up arrow and down arrow.
Regards
damnor01
I have SAMSUNG LCD 943 MWX monitor which is 19"
This is not a monitor problem.This is a mother board problem, some mother boards are supporting this resolution.For this problem,you have to replace the mother board or put the graphics card on the same mother board.your problem will solve.
Monitor turns itself off after
It may have dying power supply due to bad caps as shown here:
http://s807.photobucket.com/albums/yy352/budm/Samsung%20943T/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
I have a samsung syncmaster
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
