20 Most Recent LG W1934S-BN 19" Monitor Questions & Answers
pieter
the manual covers this.
hole the menu button in for 15seonds release and unlocked.
that is a generic answer. the manual is free to read on online.
1st google hit. and page 8
https://www.manualslib.com/manual/243261/Lg-W1934s-Bn.html?page=8
LG W1934S-BN 19"... | Answered on Apr 19, 2019
Please see here:
http://s807.photobucket.com/albums/yy352/budm/LG/LG%20W1934S/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
LG W1934S-BN 19"... | Answered on Oct 05, 2013
same problem, but not capacitors
LG W1934S-BN 19"... | Answered on Apr 12, 2013
Usually this is because the display has been changed from 16:9 (widescreen) mode to 4:3 (standard) mode. On the front panel there's a button labelled "4:3 in Wide." Press this button to return to Widescreen mode. If it says "OSD Locked" then you need to hold the "Menu" key for several seconds to unlock the controls, before changing it to widescreen.
If that doesn't correct the problem then you need to adjust your computer's output resolution to a 16:9 ratio like 1920x1080 (1080p) or 1280x720 (720p.)
LG W1934S-BN 19"... | Answered on Oct 25, 2012
This is usually a sign that the controller for the mini florescent bulbs went out. but try it on another computer maybe its your video card.
LG W1934S-BN 19"... | Answered on Dec 30, 2011
Does your PC has plugged in video card, you can try reseating it first? If it has integrated video card in the mother board, then there may be not much you can do.
Did you install any new software or update any drivers?
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
LG W1934S-BN 19"... | Answered on Nov 21, 2011
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
hope this helps you
LG W1934S-BN 19"... | Answered on Oct 20, 2011
the problem will be in power supply.
check the 5 volt regulator or 12 volt regulator IC
After geting heatup the IC may malfunction.
Change the regulator IC
LG W1934S-BN 19"... | Answered on Sep 14, 2011
What OS do you have? The drivers for XP and Vista are available from LG support: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=W1934S-BN&matchedModelCode=NOT_MATCHED&searchEngineModelCode=W1934S-BN&initialTab=documents&targetPage=support-product-profile . Make sure to click on the Drivers and Software tab if you need to.
I hope this helps.
LG W1934S-BN 19"... | Answered on Jul 17, 2011
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
LG W1934S-BN 19"... | Answered on Jul 07, 2011
To find out where the problem is, you will have to try this monitor with another PC or try another monitor with this PC first to narrow down the problem.
Please post back after what you find out so we can help you further.
LG W1934S-BN 19"... | Answered on Jun 24, 2011
LG W1934S-BN 19" Monitor Logo
106 questions posted
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LG Computers & Internet
Most Popular Question
screen flashed stopped displaying
  • Computers & Internet
