20 Most Recent
Pine Technology XFX MIA78S8209 GeForce 8200 HDMI 1333Mhz FSB AMD Socket AM2+ DDR2 ATX SLI Ready Motherboard Questions & Answers
STOP : 0X0000007E
Hi there, The error message is caused by bad memory module. replace it one by one, then test again. hope this helps, let me know your progress
Display Flicking, some times it
it may be problem with motherboard drivers or else it may be virus also. Uninstall the driver and install it. if not worked pls let me know. Update the antivirus and AGP drivers
Error code d5 comes up
somethings wrong with the power supply of your PC...
try to check it..
or *********** board come to it's end..
Motherboard replacement
ok it goes with size of board and there will be screw holes under the motherboard and spacers on the holes for yours if it will only fit a micro then youll need to get a micro board if the case has room then you can get a normall size board my advice here tho is to replace the board and the cpu i would get a 775 motherboard with pci e and ddr 2 you can get one from ebay for 35 pounds new and 10 pounds used and you will get a pentum d 820 used for about 10 to 15 pounds its a cheep way to upgrade as this is in my op the best boards around and the cheepist best cpus (you can alsow get micro boards 775 socket like the bio star board ) hope this info is of some use to you
