20 Most Recent Bosch B20CS51SNI Stainless Steel Side by Side Refrigerator Questions & Answers
0answers
0answers
Is my Bosch water tube supposed to be hot?
I am guessing your question about the "water tube" you mean the water line coming into your refrigerator. If this line is hot it is likely that it is connected to a hot water line instead of a cold water line. This will cause longer freeze times for your ice maker and longer time to cool drinking water, if you have a water dispenser. This is consuming more energy raising your utility expense every month. I recommend you find a cold water line to connect to. If you are comfortable doing this you can purchase everything you need at either of the big box stores, if not then I suggest you call a good plumber.
1/21/2013 12:14:01 PM • Bosch B20CS51SNI... • Answered on Jan 21, 2013
0answers
Ice Maker will not stop making ice
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/24/2011 1:44:23 AM • Bosch B20CS51SNI... • Answered on Aug 24, 2011
Freezer won't reached desired temp or make ice
Most definately you do. somehow air got in while you were away. 12 hour defrost with doors open will help.(insulation in side by side normally thick).Had one like that approx. 2 months ago but fridge was not well treated and they damaged rubber seal at water and ice dispencer area.
6/6/2010 12:30:37 PM • Bosch B20CS51SNI... • Answered on Jun 06, 2010
B36CL80SNS in Demo Mode - Help Troubleshooting?
To Exit Demo Mode: Hold down the Start/Reset button for 3 seconds. The display will show: 0:01 2. Press the button and the Delay Start button at the same time.
1/8/2024 4:42:45 PM • Bosch... • Answered on Jan 08, 2024
Bosch Series 2 KGN34NWEAG Fridge Freezer. The alarm sounding/not cooling in fridge compartment.
Call them out under warranty. the circulation fan is normally at the back of the fridge. On such a new fridge, so shouldn't need to be fixing issues. A fan is an 'electrical component', not an electronic item. https://www.google.com/search?q=Bosch+Series+2+KGN34NWEAG+Fridge+Freezer+warranty Refrigerators
  • Limited warranty, entire appliance, parts and labor (1 year).
  • Limited warranty for non-electronic components; parts only (1st to 2nd year).
  • Limited warranty for electronic components; parts only (2nd to 5th year).
  • Limited warranty for rust-through on stainless steel; parts only (lifetime).
10/3/2023 6:56:21 PM • Bosch... • Answered on Oct 03, 2023
How to access light bulbs on a Bosch KGU6655/07 fridge freezer please.
This page of the manual refers https://www.manuals.ca/bosch/kgu6655/manual?p=29 And I found this There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the third tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
7/15/2023 3:00:07 PM • Bosch... • Answered on Jul 15, 2023
My Bosch KAN58A70 side by side fridge operation intermittent. Fan and compressor off with unit on.
Make sure condenser coils are clean they can be readily accessed from behind or under the unit, you should clean them every 6-12 months.
7/1/2023 5:41:45 PM • Bosch... • Answered on Jul 01, 2023
Bosch B20CS51SNI Stainless Steel  Side by Side Refrigerator Logo
19 questions posted
Top Bosch Refrigerators Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Bosch Refrigerators
  • Bosch Refrigerators
Most Popular Question
bosch water tube supposed hot
  • Refrigerators
