20 Most Recent Philips 42PFL5603D 42 in. LCD HDTV Questions & Answers
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check the tuner. If tuner has any fault, this kind of fault can occur.
Philips... | Answered on Oct 27, 2015
try to reset to factory default Robert. If you can and the fault persists it is almost certainly a hardware fault that will need the attention of a competent technician
Philips... | Answered on Jul 03, 2015
Tried tv and cables or satalites boxes unplug,replug it back like about an hour later.The tv will be reset itself back to the factory setting and the those boxes will updated it softwares.The tv should be working again.
Philips... | Answered on May 25, 2015
Hi
There are many causes for a black screen on LCD's.
- Power supply failure
- Main board failure
- Faulty inverter board or CCFL failure
You do not give much detail about everything that can be observed without opening the unit: Does the front LED power on and stays on?
Does it switch to standby instantly?
Is there any sound other than the "clicking" you have mentioned? How about TV programs audio?
If I understand correctly, you can get the unit to power up by using a hairdryer??
If that is the case the fault may very well be a loose connector or a broken track. In some instances the heat expands and flexes the circuit boards, restoring the connection and you get a picture. Why not try instead gently tapping the boards with the handle of a screwdriver to see if you can get a picture that way. If you do there is your answer.
Where did you read about the use of a hair dryer?
It should NOT be used!!! Heat is the enemy of electronic components in particular IC's and capacitors, it shortens the life of IC's, dries capacitors rendering them useless thus making repairs more difficult and costly.
Hope this helps.
Philips... | Answered on Oct 03, 2014
I would first look at the power supply board. it might be a removable fuse. unplug the TV first, remove the back of TV check the area to where the power cord comes into the TV. it should be real close to the power supply board.I have had a couple of quick fixes by just replacing the fuse. (that means it did it's job) if that doesn't fix it try to get the part # from the power supply board and check with Shop Jimmy.com for replacement board. (easy fix) take pictures of the back of TV with cover off and of the power supply board before u do anything. Leave the old board in place till the new one comes in. that way you won't forget where the cables went etc. Just be careful cause the dead board can still hold a charge so handle with care.
Philips... | Answered on Sep 22, 2014
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Philips... | Answered on Sep 17, 2014
Everytime I worked on this set I have found bad connections in the power supply or on one of the inverter transformers
Philips... | Answered on Jan 01, 2014
from looking at a picture (i found) of the power board there could be a fault with the capacitors the three next to the heat shield. it is on the power out part. this area would be prom to get hot and weaken the capacitors. check them for rounding tops. replace for like to like.
Philips... | Answered on Sep 21, 2013
Should be a back-light problem itself. If you wish to know more about the back-light system of this Philips TV, check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option. http://electronicshelponline.blogspot.com/
Philips... | Answered on Jun 25, 2013
Every 3d set we have seen it isnt something you turn on. The content or channel is either 3d or not and you put glasses on and watch.
Philips... | Answered on Jan 20, 2013
Click here to download the user manual to your Philips TV, and check its specification page. You can see compactable video formats that the TV can accept. Check it with your computers video out format.
Philips... | Answered on Oct 14, 2012
That sounds like your back light has gone out. Either the back light or it's power supply failed. If you turn it on and get close a bit to the side you should see a ghost image. That will confirm it is a back light instead of a video section problem. A lcd type display creates the images on the lcd panel, but it doesn't generate any light. The backlight shines through and illuminates the images. Very much like a slide or move projector.
The repair cost really varies from model to model. The actual backlight can be repaired for under $150 in most cases. How ever if the power section is part of the main tv board then the entire main board needs to be replaced. That board on other sim sized tv's can run over $450. This is covered under warranty so the first thing you need to do is check if you have any warranty either extended store or the oem warranty. Then contact the store you purchased or go through the Phillips support to find your local repair depot and get ti sent in. If you do not have warranty then you have to be careful as you are paying for this. You need to get a estimate. A repair depot will have a very good idea of the repair cost.You should also have an idea of what a replacement tv is worth. Once you know how much the repair cost is you can then judge if it is worth fixing or if you should get a new tv. A new tv has a new warranty while your repaired tv will not. So if the repair gets too high you are better off replacing and not having any worries.
Philips... | Answered on Sep 24, 2011
Philips 42PFL5603D 42 in. LCD HDTV Logo
63 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
when turn tv its ablack screen clicks in
  • Televison & Video
