20 Most Recent Sony VAIO VGN-NR285E/T Laptop Questions & Answers
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sony VAIO... | Answered on Jan 01, 2014
It happens when DVD has large data on it ,or you are trying to install some game .I suggest you to insert the DVD in the drive and then restart it ,as windows will reload ,it will read the DVD drive as well ,it works for me sometimes.
Sony VAIO... | Answered on May 26, 2013
Hi there, visit a computer shop and ask them for an audio video data cable. Also you must inform which connector or port you have in your TV. Thanks.
Sony VAIO... | Answered on Mar 13, 2010
Either the BIOS has lost the hard disk configuration or the hard disk controller has failed or the hard disk is faulty.
Go into the BIOS configuration and see if it detects the hard disk. If not
then re-seat the hard drive and then boot up the Sony laptop.
If it still does not boot up or detects the hard disk, then to determine if the hard disk is faulty, remove the hard disk and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. This computer should see this as an external hard drive and if you can open the folders and files then the hard drive is OK and the fault is probably a faulty hard disk controller. This is a motherboard problem.
If you cannot detect the hard drive then the hard drive is faulty. To get the laptop working again, replace the hard drive, install Windows, install the Sony's device drivers and your programs.
Sony VAIO... | Answered on Jan 28, 2010
I would try a system recover before the last ditch effort in replacing the card itslef inside the unit. I would excersize all warrenty policys from sony before trying to attempt the fix yourslef if its out of warrenty try a system recovery if that doesn ot shore up the issue replace the Wifi card there is nothing else I could bring up to try at this point. Please do leave postive feedback ether way for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sony VAIO... | Answered on Nov 17, 2009
I would check the volume level and make sure the microphone is not on mute. If the settings are fine, then you should update your audio driver. Search on google for you laptop model and audio driver. Install the proper driver and reboot.
Sony VAIO... | Answered on Oct 16, 2020
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution - Error Code 0xc0000185
Sony VAIO... | Answered on Aug 13, 2020
www.driverguide.com use the 2 drivers free install per day freature. it will help you for sure
Sony VAIO... | Answered on Jan 23, 2019
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sony VAIO... | Answered on Nov 30, 2018
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu?
thanks
This can be a faulty inverter or a faulty CCFL lamp. Pleaseclick on this link and follow my instructions to identify the fault andpossible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Check this Sony's website:
Original Drivers Package
Sony VAIO... | Answered on Oct 09, 2018
Try to:
Open Computer by clicking the Start button and then clicking Computer.
Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
Sony VAIO... | Answered on Sep 30, 2018
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
Sony VAIO... | Answered on Aug 11, 2018
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
Sony VAIO... | Answered on Jan 22, 2018
Hello -
Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home.
Perhaps the information here will prove instructive:
https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences
Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
Sony VAIO... | Answered on Dec 28, 2017
Ewwwwwww... no fun.
You should try a "POWERED"
4 Port USB 3.0 Hub It's important that it's a "POWERED HUB" because you need the HUB to supply it's OWN power and not depend on your Apple E to provide power to your connected USB devices!
The good news is they don't cost much: $8 on eBay
Auction: 202096902632
Note that they include the power supply! Many other HUBS don't.
Your HUB is even LESS if you pick on the USB 2.0. Version, AND YES, each HUB MUST have it's own power supply and that's just what YOU need.
The ONE thing I didn't like about this HUB is the LED lights that are provided for each port! They are TOO bright so I opened it up and plucked all but one LED out. I also bought the 8 and 10 Port HUB versions and 'fixed' them too.
I also didn't need the switches to confuse things (accidentally turn one or more ports OFF)... so my trusty hot glue gun fixed that! All are constant ON now.
Anthony
Black 4 Port USB 3 0 Hub On Off Switches AC Power Adapter Cable For PC...
Sony VAIO... | Answered on Dec 02, 2017
Sony VAIO VGN-NR285E/T Laptop Logo
Popular Tags
7 questions posted
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
cable need send video from laptop
  • Computers & Internet
