20 Most Recent Sony Cyber-shot DSC-W130 Digital Camera Questions & Answers
Probably moisture in camera
Sony Cyber-shot... | Answered on Apr 25, 2017
I'm glad to provide the information about the Camera. The Camera does not have a RESET button to press manually to reset it.
If you wish to reset the Camera, you can use the Initialize option from the Menu item to perform it if the Camera is allowing it.
Please perform a power resetting if the Camera is not turning ON or you're unable to access the Menu items. Please follow the below steps to perform a power resetting
  • Remove the battery from Camera.
  • Press and hold the Power button for more than 15 seconds.
  • Reinsert the battery
  • Turn ON the Camera.
Thanks for understanding. Please let me know if you require further assistance.
Sony Cyber-shot... | Answered on Sep 12, 2016
Perhaps you only changed the settings. As long as you are on automatic, and don't force the flash off, the flash should work when needed.
The multiple flash you mention, is the flash used to avoid red eyes.
With the first flash(es) the eye closes the pupil, so ref;action of the retina is minimal.
Sometimes the camera also uses the returning flash light to fine tune the focus, if on auto focus.
Just check if the camera is in the setting you always used. Just check if you have the best results with this setting.
Sony Cyber-shot... | Answered on Mar 10, 2014
Turn off the camera, remove the batteries from the camera and wait a few minutes. Replace the batteries and turn the camera on.
If still not working, reset the device with either the reset button or thru the settings menu.
Sony Cyber-shot... | Answered on Nov 20, 2013
Question is, Is your lens blurred,or are all your pictures blurred?
If you can see the front of the lens is really dirty, you could try to clean it with a lens pen. One side has a soft brush to remove the dust and perhaps other debris. Please try to remove debris with a little presuerd air. If only smear is left on the lens, you than can use the other end of a lens pen. It has a very soct pad, with wich you than can remeove smear.
If the lens looks ok, please don't touch it.
Perhaps you don't take enough time to let the camera focus on the subject.
When making a picture, press the shutter release button half, till he AE/AF indicater flashes and you hear a beep, then you can press down and make the picture.
If you are making pictures without a steady hand, pictures also can come out blurred. Special when there is little light avalible.
Then choise a higher ISO.
I hope this helps. You still can fine the manual online.
Sony Cyber-shot... | Answered on Nov 05, 2013
( CARD READER TO PC)
The best and easy way is took out the memory card from the camera & insert in the memory card Reader. Then connect card reader with the PC. Now open My computer and there you can find removal disk driver ( For Example G: ). Open the driver and copy all the folders from there to your computer. After complete the transfer open the folder. You will find all the photos there. b>OR
( CAMERA TO PC USED USB CORD )
Connect the camera with data cable and turn on the camera. After that open My computer and there you can find removal disk driver ( For Example G: ). Open the driver and copy all the folders from there to your computer. After complete the transfer open the folder. You will find all the photos there. http://www.ehow.com/how_2282213_transfer-pictures-from-camera-computer.html
Sony Cyber-shot... | Answered on Aug 10, 2012
i suggest you connect your camera to a laptop or pc and extract all the images via the camera using the camera as memory card reader once done remove the memory card and format it
Sony Cyber-shot... | Answered on Aug 08, 2012
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sony Cyber-shot... | Answered on Jul 20, 2012
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Sony Cyber-shot... | Answered on Aug 20, 2011
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Sony Cyber-shot... | Answered on Aug 17, 2011
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Sony Cyber-shot... | Answered on Jun 08, 2011
hi you might check battery first. sometime battery goes bad. if not then main pcb is the problem. your local repair shop could charge around $50 depend on what they really want to charge. Thanks...best regard!
Sony Cyber-shot... | Answered on May 22, 2011
Consider NOT using the USB connection.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sony Cyber-shot... | Answered on Apr 11, 2011
I am facing the same problem. . . have you found a solution??
Sony Cyber-shot... | Answered on Apr 04, 2011
reinstall the software for the camera ,then try again if not purchase a card reader
Sony Cyber-shot... | Answered on Apr 01, 2011
Sony Cyber-shot DSC-W130 Digital Camera Logo
70 questions posted
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
suresh Kulkarni
suresh Kulkarni
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
turn power off
  • Cameras
