20 Most Recent Pentax Optio M50 Digital Camera Questions & Answers
if you are getting lines on screen and photo then there is probably something wrong with the sensor.
If it was just the screen its dead pixels in the screen. Unlikely to be a foreign body, eg hair or dust, inside as there is no way to open this camera up like a dslr.
to test this just take a photo of a plain grey card, and check the result.
Pentax Optio M50... | Answered on Jan 04, 2016
Not even when you press the display button several times? how can you see what you are framing?
Do you have pictures on the memory card? if not, the sensor is defect. (or the logic board, but both can't be repaired for less than a new camera will cost)
Pentax Optio M50... | Answered on Feb 25, 2015
How old is the battery? The camera will exhibit this behavior if the battery voltage is too low. The battery is likely undercharged, old and unable to hold a charge or the contacts are dirty. Carefully clean them with a pencil eraser, taking care not to leave debris in the battery bay.
Pentax Optio M50... | Answered on Jan 24, 2014
After you took a picture you have to press the > button, to view the picture. I can't find any setting so the camera will show each picture after you took it.
There is a short version of the manual online.
Pentax Optio M50... | Answered on Nov 20, 2013
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.Download this photo recovery software called asoftech photo recovery
http://downloads.phpnuke.org/en/download-item-view-y-y-b-b-g-m/Asoftech_Photo_Recovery.htm
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Pentax Optio M50... | Answered on Dec 20, 2012
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Pentax Optio M50... | Answered on Oct 28, 2012
Yes. There's an "Image/Sound Copy" command in the playback menu.
Be aware that if you've done any editing at all on a computer (opening a picture in a picture editor and then saving it without doing anything counts as editing) then the camera may not display it.
Pentax Optio M50... | Answered on Aug 09, 2012
there is only problem with your battery please replaced with good one it will work fine.
Pentax Optio M50... | Answered on Nov 13, 2011
try this remove SD card from camera, put it into a SD USB converter, use this on the PC and Format the SD card FAT16, this should remove all data. return SD card to camera, the camera may then want to format the card itself, if so this is all OK.
Also ensure that the little protection switch, on the SD card if there, not all have one, is set correctly... toggle it if there.
Pentax Optio M50... | Answered on Sep 10, 2011
Please try this web site for your device drivers for your camera.
Bitte versuchen Sie diese Website f?r Ihr Ger?t Treiber f?r Ihre Kamera.
http://driver-update-download.com/solved-pentax-optio-m50-usb-device-driver-update-download/usb-drivers/usb-driver-update-103/
Machen Sie einen sch?nen Tag.
Pentax Optio M50... | Answered on Aug 22, 2011
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support
heatman101
Pentax Optio M50... | Answered on Aug 08, 2011
The sd card will have a sliding switch on the left side just slide the switch up so it is not locked anymore.
Pentax Optio M50... | Answered on May 05, 2011
The quickest way to do that is to attach the camera with a USB to the computer directly without any card inserted. Then click Start/My Computer and your internal memory folder should appear as an external memory along with C: D: etc.
There may be also a similar way using the software provided by Canon when you bought the camera?. Hope this works.
Please rate Fixya answers.
Pentax Optio M50... | Answered on Feb 18, 2011
Pentax Optio M50 Digital Camera Logo
52 questions posted
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
accidently deleted all photos
  • Cameras
