20 Most Recent Nikon COOLPIX S52 Digital Camera Questions & Answers
Horizontal lines have appeared on the screen what has caused this and can I get rid of the lines.
The LCD in the viewfinder likely has connection problems or broken circuits. Did you drop it recently? Was it subject to extreme temperature etc recently? You may find the lines shift around or even go away for some time. That would imply bad connections. If your technical enough to disassemble it, there is often a rubberised connector use between the LCD and circuit board that can be cleaned. It's delicate work tho.
10/15/2017 8:54:26 AM • Nikon COOLPIX... • Answered on Oct 15, 2017
Where can I obtain a service repair manual?
[PDF]User's Manual
cdn-10.nikon-cdn.com/pdf/manuals/coolpix/S52_S52c_EN.pdf
provided with your Nikon product are trademarks or registered trademarks of ... only with the COOLPIX S52), or by ... accordance with the instructions, may.
User's Manual - Coolpix S52 / S52c ' Nikon Knowledgebase
https://support.nikonusa.com/.../users-manual---coolpix-s52-%2F-s...
NikonApr 21, 2008 - Nikon Coolpix S52 / S52c - User's Manual. This guide discusses features and usage of the Coolpix S52 / S52c Digital camera. Image ...
COOLPIX S52 from Nikon
www.nikonusa.com/en/nikon-products/.../coolpix-s52.html
Nikon3 days ago - New EXPEED Image Processor ensures high-quality pictures with stu
1/8/2016 11:19:59 PM • Nikon COOLPIX... • Answered on Jan 08, 2016
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
1/8/2016 11:19:10 PM • Nikon COOLPIX... • Answered on Jan 08, 2016
How can I get my camera out of movie mode?
If your camera acts strange, or does unexpected things, try you remove the battery. Don't remove the battery as long as the memory access light is flashing. Then after a few moments reinsert the battery. This will restart the camera like a cold boot on a computer. Then again try the shooting mode button, to go to the mode you want. (Record stills)
8/26/2014 11:17:17 AM • Nikon COOLPIX... • Answered on Aug 26, 2014
Cannot transfer photos from camara to pc
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Nikon Transfer or Picasa ( http://picasa.google.com ).
4/16/2014 4:01:23 PM • Nikon COOLPIX... • Answered on Apr 16, 2014
How to delete all pictures
The best way to delete all pictures is to format the memory, whether the internal memory or the memory card. Formatting wipes out all information and prepares the memory for further use, avoiding the potential problems that can come from repeatedly deleting individual pictures.You'll find the format command in the Setup menu. To format the internal memory, remove the memory card first.
12/13/2012 4:47:09 PM • Nikon COOLPIX... • Answered on Dec 13, 2012
How to use nikon s52 as webcam.?
The S52 is designed to store high resolution images and videos to memory, not to stream low-resolution videos to a computer. Besides the fact that you would be wasting 99% of the camera's capabilities, this would also drain the battery too quickly.
5/16/2012 4:55:35 PM • Nikon COOLPIX... • Answered on May 16, 2012
How do I change coolpix s52 to change from internal memory to sd card?
Try formatting the SD memory card using the camera's Menu setting.
5/5/2012 8:52:00 AM • Nikon COOLPIX... • Answered on May 05, 2012
I keep getting len error
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
9/17/2011 4:23:45 PM • Nikon COOLPIX... • Answered on Sep 17, 2011
I lost my coolpix S52 cd-rom and I wasn't sure
You can download a copy of the manual from
http://support.nikonusa.com/app/answers/detail/a_id/14559
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
6/23/2011 4:47:03 PM • Nikon COOLPIX... • Answered on Jun 23, 2011
Hi sir, gk here, having
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
6/17/2011 4:17:31 AM • Nikon COOLPIX... • Answered on Jun 17, 2011
My Nikon Coolpix S52 is not being recognized by
Consider NOT connecting your camera to your computer.
4/3/2011 1:08:22 AM • Nikon COOLPIX... • Answered on Apr 03, 2011
When i switch on my camera it shows "memory card
There is possible two things that are preventing you from using the memory card first there is a small switch on the side of the SD card I'm providing a diagram to show you. Make sure the little switch is in the correct position.
Next and most probably the main thing is the memory card needs to be formatted to the camera it is being used in. Formatting some times called initializing prepares the memory card surface to receive camera data and picture files. Formatting should be done each time a new memory card is going to be used in a camera and after each time the picture files are downloaded to the computer.
If you have been using this card and only deleting the picture files what has happened is that there is a small file left on the card each time you delete after a time these little files clog the memory card to a point the card can not receive any new data. Formatting is the way to clear off all this impertinent data and start fresh.
Cheers have fun with your camera.
3/15/2011 11:48:25 AM • Nikon COOLPIX... • Answered on Mar 15, 2011
When trying to copy the photos from my pc back to
Hi, you sure re use transfer mode ,this way move the picture to a pc recheck your setup for keep in card.
Regardss
2/26/2011 4:35:30 PM • Nikon COOLPIX... • Answered on Feb 26, 2011
I have this Camara for
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
1/25/2011 11:47:11 AM • Nikon COOLPIX... • Answered on Jan 25, 2011
tip
Nikon CoolPix S52
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-S52-Digital-Cameras-review-manual/id/17150bh332/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
Red blinking sign
No, they're not connected.
Go into the setup menu and set the date and time. This will get rid of the blinking red clock.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use iPhoto or Nikon Transfer or any other photo cataloging program.
12/26/2010 11:41:38 PM • Nikon COOLPIX... • Answered on Dec 26, 2010
Nikon COOLPIX S52 Digital Camera Logo
52 questions posted
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
horizontal lines appeared screen caused
  • Cameras
