20 Most Recent
Nikon Coolpix S510 Digital Camera Questions & Answers
Nikon coolpix s510 keeps turning on
See if there is a way to check out the power button. If the contacts are stuck in on position or unstable it is possible that the unit is behaving erratically. Try cleaning it out chemically if possible.
How to turn off the
Press [up] on the multiselector (marked with a lightning bolt) to bring up the flash menu. Use [up]/[down] on the multiselector to select the lightning-bolt-in-a-circle-with-a-slash-through-it symbol to turn off the flash.
Don't forget to turn it back on later.
Full details are in the "Using the Flash" section of the manual (page 40 in my copy). If you need a copy of the manual, you can download one from
http://support.nikonusa.com/app/answers/detail/a_id/14388
The Battery provided does not
change the battery.... i think it is over charge.... usually a good indication is that the battery is deformed.... also compare batteries amperage.....
Is it possible that the
Yes it is! the manufacture suggest taking the battery out if the camera sits idle for weeks and months, that way you can have the full use of the battery.
Lens Cover Error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
