20 Most Recent Kodak Easyshare M893 Digital Camera Questions & Answers
get a quote for repairs from a camera shop or junk it
The carry strap is not just for decoration but to place around your neck so that the expensive item doesn't hit the floor if dropped
Kodak Easyshare... | Answered on Dec 02, 2017
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Kodak Easyshare... | Answered on Jul 13, 2015
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Kodak Easyshare... | Answered on Apr 21, 2015
If a camera has a software problem, the only thing you can do is remove the battery and reinsert it. This way you give the camera a cold boot. Like switching on a computer.
But it is more likely your battery is flat. Or contacts from battery and or in the battery compartment are dirty or oxidised. Check all contacts and eventually clean them. Never use anything sharp in or close to a camera. Clean with a cotton swap or a dry cloth.
Recharge the battery (Batteries) and if that does not help try another battery.
Kodak Easyshare... | Answered on Feb 22, 2014
keep the camera on with full battery charge, hold the camera in your left hand and whack the base with your right hand, switch on and off the camera immediately, this will if the lens has got misaligned due to knock etc
Kodak Easyshare... | Answered on Nov 15, 2013
hello.. your problem is not your computer,, your problem is about uploading picture from your camera
make sure your picture want you to upload is jpg files type..the uploading picture is must jpg type of files,, you able to change the file type of your picture ,,, how to change? open your picture and save again with select file type choices
or the to upload using other internet connection or upload using other computer to chick if your computer is not your problem,,, thank you hope i can help you have a good day!!
Kodak Easyshare... | Answered on Jun 19, 2013
If you are referring to the lens not coming out then the camera has serious problems, These models have a lot of problems. not a dependable camera by any means.
Kodak Easyshare... | Answered on Jan 24, 2013
This is the Kodak camera section !!!!!!!
user guide:
http://support.en.kodak.com/app/answers/detail/a_id/18900/kw/m893
extended user guide:
http://support.en.kodak.com/app/answers/detail/a_id/18897/kw/m893
Kodak Easyshare... | Answered on Sep 11, 2011
Welcome to FixYa.
For camera's that won't turn on or will turn on but automatically turn off. First thing you need to check if the battery was fully charged.
Second, check if the battery was placed in right direction.
If those two solution was done, You need to removed the battery and re-insert it again.
Also try to install new fully charged battery.
If this issue will continue you need to contact your service center because this might have a camera malfunction.
Feel free to send us your comments or suggestion if this solution was helful.
Thank you for using FixYa.
Kodak Easyshare... | Answered on Apr 08, 2011
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Kodak Easyshare... | Answered on Jan 24, 2011
In any still mode, press the cursor-down button (marked with a one-handed clock) to cycle through the available self-timer modes. Start the self-timer by pressing the shutter release button.
Kodak Easyshare... | Answered on Dec 15, 2010
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Kodak Easyshare... | Answered on Sep 24, 2010
1/ Make sure your battery is still good (holds charge). If it does hold charge, 2/ then turn the camera on by pressing the play button. If it turns on, your camera's lens is faulty
Kodak Easyshare... | Answered on Aug 17, 2010
Having gone over a month with no reply, I assume this is no longer a problem.
Kodak Easyshare... | Answered on Jul 15, 2010
Choose your color from http://uscamera.com/m893.htm
Kodak Easyshare... | Answered on Jun 14, 2010
turn cam on and grab hold of lens and try to wiggle it back into alignment.
Kodak Easyshare... | Answered on May 12, 2010
What exactly did you try?
Check these:
  • Fully charged batteries
  • Taking batteries our from the camera and reinserting
  • Other set of batteries
If you did try all of the above without success, the only thing you could do is take the camera to a local electronist, or Kodak dealer for repairs.
Kodak Easyshare... | Answered on Apr 09, 2010
Sounds like a lens problem. Try these... Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Kodak Easyshare... | Answered on Mar 29, 2010
Kodak Easyshare M893 Digital Camera Logo
54 questions posted
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
user manual kodak easyshare m893 digital
  • Cameras
