20 Most Recent Kodak EasyShare V803 Digital Camera Questions & Answers
Kodak easyshare v803 screen not working
Hi! Please check the "Troubleshooting" part of the manual to this camera. https://manualsbrain.com/en/manuals/1041829/?page=54
10/27/2017 10:43:35 AM • Kodak EasyShare... • Answered on Oct 27, 2017
Were can I buy a replacement battery 1050 37v
Try ebay
7/19/2013 7:51:58 PM • Kodak EasyShare... • Answered on Jul 19, 2013
0answers
Hi, have kodak easy share v803. Have had about 4 yrs. it makes a ticking noise.
Hello Dawn, You really need to get this checked out soon, the longer you wait the more serious this will become.
1/24/2013 10:34:49 PM • Kodak EasyShare... • Answered on Jan 24, 2013
My kodak easyshare V803 camera will not read memery card old or new says unuseable
if it's not reading old or new you might have to format the memory card on your computer first... all you do is put the memory card in the computer and you go to my computer and look for the drive... if the drive is not there then you will have to go to kodak and look up there driver readers and download it then it should work... also sometimes a camera can only take certain gb so you might have to down size... i hope this helps you out
5/22/2012 4:31:36 PM • Kodak EasyShare... • Answered on May 22, 2012
What do you do when camera says internal memory
Digital cameras store pictures on their internal memory. Often users transfer their photographs to memory cards, because memory cards store more data and are accessible in computers, other digital cameras and other devices. When you want to move pictures stored on the internal memory card, do so through the camera's menu
1 Place the memory card into the digital camera.
2 Turn on the digital camera.
3 Access the digital camera's menu. Digital cameras have a button labeled "Menu" near the LCD screen. Push this button to open the menu.
4 Select the Pictures option. Select the photos on your internal memory using the "Select" or "OK" button on the arrow pad on the back of the camera. Click "Copy" and choose "Memory Card" to copy the files to the memory card. If there is more than one picture that needs copying to the memory card, perform this step for each picture.
Have a good day! Smile : )
9/4/2011 2:23:51 PM • Kodak EasyShare... • Answered on Sep 04, 2011
My camera will not turn
hi your statement isn't clear. would you give more detail. (like outside of shape, lens out position, when switch on how it respond momentarily--light blinks? etc..) Thanks
5/22/2011 4:00:52 AM • Kodak EasyShare... • Answered on May 22, 2011
My camera stopped uploading photos
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
5/13/2011 5:33:45 PM • Kodak EasyShare... • Answered on May 13, 2011
My camera is frozen in the open position. I can't
remove the battery and put it back again
1/2/2011 6:41:39 PM • Kodak EasyShare... • Answered on Jan 02, 2011
Loaded software for kodak easyshare v803 cam but
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
12/29/2010 7:16:23 AM • Kodak EasyShare... • Answered on Dec 29, 2010
I have a Kodak Easyshare Digital Camera V803 . I
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. And if you have to buy a card reader, it's not going to cost you any more than a new cable.
12/22/2010 7:47:32 PM • Kodak EasyShare... • Answered on Dec 22, 2010
Camera V1003 no longer charges,
Sounds like a battery adapter problem to me, coz you have already replaced the battery. I am positive that a replacement adapter will resolve your problem.
12/16/2010 3:59:31 PM • Kodak EasyShare... • Answered on Dec 16, 2010
The shutter/lens will not close
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
8/18/2010 8:44:51 PM • Kodak EasyShare... • Answered on Aug 18, 2010
All of a sudden my camera wont upload pictures
6/16/2010 8:54:53 PM • Kodak EasyShare... • Answered on Jun 16, 2010
I HAVE A KODAK EASYSHARE V803 AND THE SCREEN IS
L.C.D broken to be replaced
5/8/2010 4:37:52 AM • Kodak EasyShare... • Answered on May 08, 2010
Pictures won't load
Use a card reader instead of your camera.
4/11/2010 11:23:48 PM • Kodak EasyShare... • Answered on Apr 11, 2010
Kodak EasyShare V803 Digital Camera Logo
39 questions posted
Top Kodak Cameras Experts
Ekse
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
made picture kodak v803 don 39 t know
  • Cameras
