20 Most Recent Laser Canon imageCLASS 8180C Multifunction Printer Questions & Answers
Here's your support page. If you search "e000" you'll receive the following solutions.
Solutions
for e000 Issue: ERROR LCD: System Error E000
1. Reseating the Fixing Assembly-ICMF 8100 2. Resetting the machine-ICMF 8100 3. Verify/reconnect power cord to fixing assembly
Laser Canon... | Answered on Mar 28, 2017
Are you using 3rd party cartridge or OEM replace the cartridge with OEM. Which cartridge does it say to check does your machine, have separate drum and toner cart. replace the right one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Laser Canon... | Answered on Nov 22, 2015
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : -http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Laser Canon... | Answered on Jul 10, 2012
To resolve the issue, please try reseating the fixing assembly. To do so, please follow the instructions below:
1) Unplug the power cord from the wall outlet.
Caution: The fuser unit and surrounding area can become extremely hot during operation. Perform the following procedure after the fuser unit has cooled down completely. Touching the fuser unit when it is still hot may result in burns. skumar_sreen_0.gif
2) Turn the lock release levers located on the back of the machine in the direction of the arrow and release the lock. skumar_sreen_1.gif
Caution: The fuser unit weighs approximately 3.3 lb (1.5 kg), and it is heavier on the back side. Be sure to hold the grip securely when carrying a fuser unit. Dropping the unit may result in personal injuries. skumar_sreen_3.gif
4) Hold the grip on the fuser unit and install it securely. skumar_sreen_4.gif
5) Lock the fuser unit by turning the two lock release levers in the direction of the arrow. skumar_sreen_5.gif
6) Connect the power cord and all interface cables.
7) Plug the power cord in the wall outlet to turn on the machine.
Laser Canon... | Answered on Aug 30, 2011
There are Many MF8180C out there...and they are a good machine...however they had a Manufacturing FAULT and that is the POOR Quality of one Small plug on the FUSER unit RU5-8125....The FEMALE PLUG in the BACK of this machine has faulty Female Pins that Can and DO get pushed back into the base of the PLUG when the fuser is removed and reinserted...
Initally People THINK that the Fuser is BURNT out...BUT
Put a Multimeter across the White leads leadinginto the Fuser and then onto the White lead going INTO the Thermostat on the RHS and you should get a Full Circuit indicating that the heating element is IN FACT still OK ! Then Put the Multimeter on the other end of the plug and TEST the THERMOSTAT with the multimeter in the OHMS setting..you should get a resistance reading....Then the Thermostat is OK also....
NOW Just Look at the PINS in the BACK of the PLUG for the FUSER...most likley one/or two are recessed back in the plug...they should all be even at the FRONT of the PLUG....
Get some tweesers and Pull the little Pins Back out...so they are all lined up....
you will need to keep them there so get a TINY amount of Sicaflex (silicone adhesive-heat resistant...) and Put that UNDER Yes UNDER the Base of the PIN !!! NO UNDER !!!!
if you put in the pin the contacts will not meet....you just need to put a MINUTE amount under this pin to hold it out there.....IF you mess this UP you will have to HARD wire the Fuser in and that is a whole other matter.....
Good Luck Everyone I know this is the issue with the 8180c !!!!
regards Tony Gordon
www.whitelightfilm.com
Laser Canon... | Answered on Aug 04, 2011
There are various resets based on different messages.
Hope this helps!
Laser Canon... | Answered on May 01, 2011
Is it a white or black line?There can be a piece of paper in the drum cartridge or the drum is damaged!Scratched!Try replacing the drum cartridge!Good Luck!
Laser Canon... | Answered on Dec 07, 2010
Hi.
Yes, it is likely a broken fuser. Probably fuser have overheated and either lamp, thermistor or both may have blown.
Let say that over 90% of the case the problem is fixed replacing fuser unit. In some case there is no power to fuser unit because a different problem has occurred.
The best thing to do is calling Canon service and asking a quote on repair. A technician will test voltage to fuser unit before replacement.
Laser Canon... | Answered on Aug 12, 2010
E078 secondary transfer roller drive
mechanism fault
Possiblle causes:
Check the connector of the roller drive sensor.
Check the connector of the roller drive clutch.
Replace the main drive assembly (roller Drive
sensor).
Replace the drum cartridge (roller drive cam).
Replace the DC controller PCB.
Laser Canon... | Answered on Jul 01, 2010
I have a Canon Color Image Class MF 8180C with a system error code E078 - Trying to understand what it means and how to clear. Any ideas?
Laser Canon... | Answered on Jun 18, 2010
You can download the Canon printer drivers from their WEB site. Please click on this link and select your model printer :-
Laser Canon... | Answered on Jun 16, 2010
If this was the case all the time, I would imagine you have an incorrect driver in the Laser Printer. You should be able to upgrade the drivers by contacting the the Canon Co.
If this is a new problem the static bar that runs across the drum has lost it's positive charge to produce the picture should be replaced ... its not cheap !
Laser Canon... | Answered on Jun 19, 2009
try to check your connection form your printer and if possible try reinstall the printer driver then try to run again the printer.
Laser Canon... | Answered on Jun 16, 2009
I agreed with Nancy. I was also reading reviews on https://reviewspack.com/best-presentation-clickers/ and https://www.thedailytell.com/best-laser-pointers-for-presentations/ Logitech Spotlight is most powerful pointer the R800
Laser Office... | Answered on Sep 13, 2020
https://www.youtube.com/watch?v=ssBRM0WAY2Q
Laser Office... | Answered on Mar 20, 2020
try unplugging it from the back, the switch might be broken.
Laser Office... | Answered on Aug 14, 2019
A fuser error is probably caused by a thermistor (detects an overheating problem). The fuser is probably best serviced by the manufacturer as an improperly serviced fuser could lead to a fire.
Laser Office... | Answered on May 30, 2019
Laser Canon imageCLASS 8180C Multifunction Printer Logo
Popular Tags
31 questions posted
Top Laser Office Equipment & Supplies Experts
efs_perpends
efs_perpends
ADMIN Canada
ADMIN Canada
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Laser Office Equipment & Supplies
Most Popular Question
system error e000 canon image class
  • Office Equipment & Supplies
