20 Most Recent RIM BlackBerry Pearl 8130 Cellular Phone Questions & Answers
If this is a Verizon phone then it most likely does not have a SIM card. If it does have one then it should be located under the battery. If your phone has a SIM card, here are the instructions for removal. Just reverse for install.
http://www.ehow.com/how_5752031_remove-sim-card-blackberry-pearl.html
RIM BlackBerry... | Answered on Mar 11, 2019
This unit is prone of freezing up due to low memory. Check your free space on your phone,make sure you are cleaning memory,by purging cache memory etc. Also when you leave a program actually select"CLOSE" button.Most people close the applications by pressing the escape or red key. This does not close the application has a CLOSE option. For instance if you are in the calendar hit hit menu key and scroll down to the bottom CLOSE is listed. Go through each application and press close. Go into the cache operations clear all categories and hit escape it will say cleaning memory. Go to options - security - memory cleaning - enable it. The BB will now clean memory when idle for 5 minutes. Hope it may helps,feel free to ask whatever the result.
Regards:
VOTIT
RIM BlackBerry... | Answered on Dec 02, 2016
RIM BlackBerry Pearl 8130 behind battery.
RIM BlackBerry... | Answered on Nov 09, 2013
In the back off the phone behind the battery.
  • www.unlocktotalk.com
  • Check out this website they are knowledable and have pretty good prices.
  • If you don;t know how to flash a cell phone, don;t attempt it unless you have hours to learn.
  • Good Luck
RIM BlackBerry... | Answered on Apr 19, 2013
Unlock Cell Phones
Your cell phone may be locked to a particular cell phone provider and in this case it needs to be unlocked to use with a different cell phone service provider. To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use the SIM card with a different phone provider, Please click on this link and follow my instructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then these WEB sites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ http://www.superunlockcodes.com http://unlockcellphonecode.com/
RIM BlackBerry... | Answered on Jan 29, 2013
I want to buy a andrioid smartphone,did you give me a favour?
RIM BlackBerry... | Answered on May 04, 2012
You can get the Unlock code from the site Theunlockspot.com/unlock-your-phone/rs10wp2/ and unlock Blackberry Phone from network lock.
RIM BlackBerry... | Answered on Apr 23, 2012
Hello
You have to unlock that BB first
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
RIM BlackBerry... | Answered on Feb 23, 2012
BlackBerry phonesare very secure. There is no way to unlock your model without paying for eithernetwork or an unlocking shop.
Independent unlocking shops have to make asignificant investment in software and tools to be able to generate unlockingcodes and the money has to be recouped quickly whilst the relevant models arestill commonplace, so they won't hand the codes out for out for free.
Once you have your code, please report back fordetailed instructions on how to enter the code into your mobile. Note that theprocess may vary for different models and is definitely different..................
instead of wastingtime to search shops to unlock your phone you can go and unlock your phone within some minutes
this site is thecheapest unlock code provider
try this Click Here
RIM BlackBerry... | Answered on Feb 11, 2012
Hi, To unlock your mobile you no need to give your serial number. You have to give your mobile's IMEI number. Type in your mobile *#06# . It will show your mobile's 15 digit IMEI number. If you need to break your network lock means, just give your IMEI number, country and network details at TheUnlockArena.com to get the unlock code for your BlackBerry 8130.
RIM BlackBerry... | Answered on Dec 23, 2011
if i try to use pearl shuts down red light stays on
RIM BlackBerry... | Answered on Dec 18, 2011
You can reset your blackberry phones then try to access that option again, if still have same result, Unlock your blackberry network using blackberry pearl 8130 unlock code. It should be unlock your network and you can try to access that option again. If your unlocked blacberry network still have same problem, go to final option to reflash your phone.
RIM BlackBerry... | Answered on Sep 06, 2011
You need blackberry pearl 8130 unlock code for verizon network to unlock your phone so you can use any of india cdma network on your blackberry pearl. Blackberry unlock code can be obtained from your original phone network provider and third party sites. Both of them take some charges, but third party sites more cheaper and more quickly rather than asking unlock code from network provider.
dial *22899 and let it reprogram. If it won't let you do that then bring up the applications window and open the "manage connections" app. Then click on the "Turn off all connections off" option. Then click on the "restore connections" option. That should do the trick.
RIM BlackBerry... | Answered on Mar 14, 2011
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
RIM BlackBerry... | Answered on Feb 15, 2011
RIM BlackBerry Pearl 8130 Cellular Phone Logo
Popular Tags
116 questions posted
Top RIM Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Marvin
Marvin
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
BlackBerry RIM
  • BlackBerry RIM
Most Popular Question
unlock cdma blackberry phone other
  • Cell Phones
