20 Most Recent
Eagle Fisheasy 320c Fishfinder Questions & Answers
Where would I send an Eagle Fish Mark 640 for repairs?
I am a bit reluctant to answer this question as it may sound like I am being rude, but here goes. Type the name into google. It will tell you this is a discontinued product, and will also tell you the nearest service place to contact which will probably be a Lowrance agent. Call them and ask if it can be repaired. If so send it to them with a note explaining what the problem is. If it cannot, throw it in the bin and buy a new one. Easy.
Can I wire it together?
The impedance match most likely won't. I advice you not to attempt. Replace with matching Eagle model transducer.
I have a eagle fish easy 240 it won't power on
1.Check the online fuse on your unit and be sure it is still intact.
2.Look at the connector on the back of the unit and be sure there are no bent pins.
3. Check the battery voltage and verify it's reading 12 volts or more.
4. Check the voltage at the connector to be sure you are getting power to the unit.
5. If you've accomplished all of this and there is power to your unit and it still won't turn on then it's time to invest in a new unit.
