20 Most Recent Vestax Vci 100 Midi Controller Questions & Answers
When you connect a hard drive and any other USB device to a 4 port hub you have to use the external power supply all the time. You may have fried the power pins on the USB port you used to connect the 4 port hub. If you can get the hard drive to work separately on the USB port, the 4 port hub may no longer be passing power from the laptop.
Vestax Vci 100... | Answered on Nov 09, 2017
Your best bet is to contact Vestax Support directly. Their USA phone number is 1(888)498-4788 Mon-Fri 10am-5pm PST
Vestax Vci 100... | Answered on Feb 09, 2015
Here is an online manual, Can't download it, though. Hope it helps.
http://www.manualslib.com/manual/399951/Vestax-Vci-100.html
Vestax Vci 100... | Answered on Mar 06, 2013
The solution is likely replacement of the button switch portion. Be careful of applying too much pressure... often they have plastic hinges for the buttons and they can be broken by applying too much pressure in an attempt to get them to work.
Vestax Vci 100... | Answered on Jun 23, 2011
well what software are you using. They is plug n play capable w VDJ and the drivers if there any should be on vestax's site or on a disk that came w the software. and if you need mappings for it meaning to your controller works with tratoktor www.djtechtools.com like i said you might not need a driver for it but let me know
Vestax Vci 100... | Answered on May 24, 2011
It is an either/or thing. I would recommend you get a headphone amplifier or get external speakers and drive them externally. Internal speakers are relatively poor quality anyway
Vestax Vci 100... | Answered on Apr 30, 2011
This is likely the button mechanism itself and will only be solved by replacement. Electrically the contacts fail,usually just from wear.
Vestax Vci 100... | Answered on Apr 03, 2011
Take it in for repair... this is NOT a DIY project.
Vestax Vci 100... | Answered on Mar 16, 2011
There probably is a conflict with the camera hardware and or driver. Your best help may be on those Vestax forums. You could try removing the camera drivers in the Sony... but it may be a hardware conflict that may have no solution.
Vestax Vci 100... | Answered on Mar 07, 2011
If it is the connector, resolder the connector to the board, carefully...
If the connector is damaged, you can get new ones from several sources, including Digikey.com and Mouser.com.
Also consider finding a connector to salvage from PC recycling outfits.
Vestax Vci 100... | Answered on Sep 05, 2010
The electronics of a USB port is fairly robust. Why do you think the USB port needs replacing? Or do you just mean the connector... Even those are fairly robust and if they wiggle, they may just need to be resoldered to the circuit board.
You don't give your location so start here:http://www.vestax.com/v/ Try contacting the two distributors here:http://www.vestax.com/v/wtbuy/ .
Vestax Vci 100... | Answered on Aug 25, 2010
hi, you need to go here:
http://help.vestax.co.jp/en/detail.php?id=80&id_page_url=56&cate=0
and download the .tks file for your version of Traktor. Suggest you save it to the Traktor program directory.
Then within Traktor in the controller settings section, load the .tks file, save and you're good to go. Obviously you can tweak the configuration as much as you like once it's loaded. Suggest you always keep a backup of the original.
Vestax Vci 100... | Answered on Mar 22, 2010
Check these out, midi mapping is extremely complex with this software. These videos are definitely the best way to learn midi mapping:
Let me know if you are still unable to get the midi mapping going.
Thanks
Tim
Vestax Vci 100... | Answered on Sep 09, 2009
I suspect this uses an optical pickup. You need to open the unit and look at the sensor. If it is an optical pickup, then use the canned air pressure to clean the area of dust.
If it happens to be a mechanical switch, then the mechanical encoder has to be replaced.
Vestax Vci 100 Midi Controller Logo
27 questions posted
Top Vestax Music Experts
Marvin
Marvin
Are you a Vestax Music Expert? Answer questions, earn points and help others
View Most Popular
Vestax Music
  • Vestax Music
Most Popular Question
vci 100 one
  • Music
