20 Most Recent Tascam 2488mkii 24 Track Recording Workstation Questions & Answers
There is likely an amplitude setting (probably available in a menu) for the click. Make sure that is turned up.
Tascam 2488mkii... | Answered on Oct 30, 2012
I'd say the click track starts from exactly when you hit play even if you've hit play not right on the beat. There might be a setting or preference that can fix this.
Try rewinding back to be right on the beat and see if it syncs with the click
Tascam 2488mkii... | Answered on Jul 01, 2011
The actual disc speed in the unit has nothing to do with the speed that a CD plays back.
Read page 68 of your user manual for variable speed and pitch setup and changing.
Tascam 2488mkii... | Answered on May 24, 2011
It sounds like the hard drive has failed... cheap test, get another and reformat the new one. They are so inexpensive now. To avoid losing data, they lock things up if anything goes wrong. The unit probably can't get the ready signal from the drive and freezes...
Tascam 2488mkii... | Answered on Apr 21, 2011
The button will either be a switch type with a small switch actuated by the button or a conductive rubber pill that is pressed against circuit traces on the board. The latter you can clean with 99% isoprophyl alcohol and Q tips. The switch type you probably have to replace the switch as the internal contacts have likely worn. Often these switches are very small and take a lot of force given the size of buttons that actuate them. Unsoldering from the board takes care to NOT damage the circuit board and the pads. Make sure the new switch is held tightly to the board before soldering in place.
Tascam 2488mkii... | Answered on Feb 24, 2011
I think if you had the manual you would know the answer.
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html Page 118... Press NO/EXIT and check the digital audio source. The output should be 44.1 kHz (note that some players output 48 kHz). A unit with varispeed (pitch control) may have varispeed turned on, altering the sampling frequency from 44.1 kHz.
Tascam 2488mkii... | Answered on Feb 20, 2011
Hello
go to this web site and download user manual
http://tascam.com/product/2488mkii/downloads/
hope this helps
Tascam 2488mkii... | Answered on Jan 27, 2011
You can run to mic connectors but will probably have to turn down the trims. DO NOT run the drum machine at too low a volume as the signal to noise ratio will suffer. Best to attenuate at the mixer.
ALL interconnected equipment should be powered from the same source or receptacle to avoid ground loops.
Tascam 2488mkii... | Answered on Jan 17, 2011
You can download a manual from the tascam site for this model. as long as you pre-named your songs, they should show in the menu without mastering. You cannot burn any songs without mastering your songs first, however. They will not appear in the create cd section for this very reason.
Record, master,burn.
Tascam 2488mkii... | Answered on Jan 05, 2011
The button switch has likely failed and will need replacing.
Tascam 2488mkii... | Answered on Dec 02, 2010
Yes, you should be able to go direct into the recording input if your guitar has a preamp in it and the 2488 may have adequate gain to even accept the input from a passive guitar.
Tascam 2488mkii... | Answered on Nov 30, 2010
It sounds like you have either a hard drive failure or have lost the internal operating system in your unit.
BE VERY careful if you have critical data as it still might be recoverable.
I would contact the factory on this one.
Tascam 2488mkii... | Answered on Nov 17, 2010
Have a look at this link:http://tascamforums.com/index.php?showtopic=8650
Tascam 2488mkii... | Answered on Nov 04, 2010
Here is a link for you to look at:http://www.tascam.com/products/2488mkii.html Look under resources to download the manual or a Beginners Guide to Recording.
Tascam 2488mkii... | Answered on Aug 30, 2010
Here is a link to the manual:http://www.tascam.com/products/2488mkii;9,16,109,19.html Go down to Resources, Documents. As far as I know you have to map your input to a track. If you want Stereo you have to use 2 tracks. The owners manual explains it better than I can here.
Tascam 2488mkii... | Answered on Aug 25, 2010
It's tough. For all that TASCAM touts this is not a user friendly system. I find that assigning compression to one track, removes my reverb from every track. It seems only one effect can be used at a time, and that effect effects them all. Tascam sucks. Never again!
Tascam 2488mkii... | Answered on Aug 17, 2010
I get a CAUTION sign when I boot up that says:
Cannot Boot! Not Detect HDD Correctly. Please POWER OFF , and Check H/W..." Can anyone assit me with resolving this problem
Thanks
Scott
Tascam 2488mkii 24 Track Recording Workstation Logo
Popular Tags
45 questions posted
Top Tascam Music Experts
Marvin
Marvin
Are you a Tascam Music Expert? Answer questions, earn points and help others
View Most Popular
Tascam Music
  • Tascam Music
Most Popular Question
using recorder locked up nothing
  • Music
