20 Most Recent Ice Cube Maker Questions & Answers
Do you have a new one? Try comparing the values. There are several types of thermistor. Do you have the type number?
Ice Cube Maker | Answered on Mar 16, 2014
HOW OLD IS THE UNIT, AFTER A WHILE THE NICKLE PLATING STARTS TO WEAR OFF THE PLATE WHICH WILL CAUSE THIS PROBLEM AND THEY ARE NOT CHEAP, ALSO CHECK ON THE BOTTOM OF THE MACHINE THERE SHOULD BE A CONTRPL THAT WILL INCREASE THE TIME OF THE RELEASE CYCLE
Ice Cube Maker | Answered on May 31, 2012
A good very experienced refrigeration guy may be able to repair the evap. coil. This will depend on exactly where the crack is....
The pipe will need to be brazed with a high temperature brazing and then the whole system vacumed down and recharged.
If the crack cannot be fixed then you be be better off to get a new machine...
Heatman101
Ice Cube Maker | Answered on Feb 28, 2010
water valve is defective or sticking
Ice Cube Maker | Answered on Jan 16, 2010
we physically do not fix anything offer advice only in this forum
Ice Kitchen... | Answered on Nov 23, 2019
The grey around the yolk of the egg when hard boiled is due to the sulfur in the yolk. Cook the eggs a little slower, slow simmer, and add a little vinegar and salt to the cooking water. I have also found that we all have the tendency to overcook hard boiled eggs which also helps create the grey around the yolk. I have found that eggs simmered for not more than 12 minutes are hard boiled but don't have as much grey.
Ice Kitchen... | Answered on Aug 14, 2019
Assu.ing that the unit has been installed properly and has been working up to know, my 'guess' is a loss of refrigerat. Assuming that the water inlet valve is energized allowing water to enter and trip the high water float. This allows the high gas valve to open, and guessing, a loss of refrigerat is detected and shuts off the operation.
These are very complex, commercial ice makers and need a qualified technician to do a proper troubleshoot of the unit.
Ice Kitchen... | Answered on Jun 12, 2019
POSSIBLY A DIRTY OR BAD SENSOR WE CAN NOT TEST IT FROM HERE
Ice Kitchen... | Answered on Dec 15, 2018
https://www.webstaurantstore.com/article/151/how-to-clean-an-ice-machine.html
Ice Kitchen... | Answered on Oct 20, 2018
Have you made sure that the unit is completely dry before restarting. And did you check the cooling fan that it's not full of dust
Ice Kitchen... | Answered on Sep 03, 2018
Ice Cube Maker Logo
17 questions posted
Top Ice Kitchen Appliances - Others Experts
jasbo
jasbo
NOEL
NOEL
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Ice Kitchen Appliances - Others
Most Popular Question
viking vuim150dlss bin t mister
  • Kitchen Appliances - Others
