20 Most Recent Sony mylo COM-2 Questions & Answers
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sony mylo COM-2 | Answered on Nov 10, 2012
no
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sony mylo COM-2 | Answered on Sep 05, 2010
u can request for change in password go to settings
Sony mylo COM-2 | Answered on Apr 23, 2010
IMPORTANT: This procedure will remove (reset) all passwords and delete all personal information, files and folders from the internal memory of the personal communicator.
If the four digit password that is prompted for when the mylo is started has been lost, forgotten, or does not work, a master reset procedure will need to be performed. To do this, on the mylo keyboard, simultaneously press and hold the FN , Sym and BS keys for at least 5 seconds. hope this helps.
Sony mylo COM-2 | Answered on Jan 23, 2010
Try this before you get it to the service :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
a related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Sony mylo COM-2 | Answered on Jan 17, 2010
Let it dry out for about a week. also was the phone on when you fell in ?
Sony mylo COM-2 | Answered on Oct 11, 2009
i reccomend going to a local sony store and getting and estimate
Sony mylo COM-2 | Answered on Jun 04, 2009
Hello there... Sony seems a choosy brand so it looks like your disc is not recognized by it. Check also your disc for scratches or you just need to clean your disc first before you can use it. Try it. If this doesn't help, try inserting your disc to other CD-ROM. See if your disc is okay. Hope this helps...
Ai-ai :)
Sony Computers &... | Answered 3 hours ago
The push-button activates a small motor that turns a small rubber belt/ band that opens the cassette door. Since it's not been used for 10 yrs, I would say these belts would have deteriorated and broken. you will need to replace them. the best bet is to open it up and check. if its the case, you should be able to source the belts on ebay.
Sony Computers &... | Answered on Dec 03, 2019
this is easy, that OUT OF range means
the PC sending video is sending and illegall higher resolution
than the projector supports (or even less, on this old junk)
the manual on that old projector is clear on that. max.
SONY VPL-EX4 2007, 13 years old now.
and back then projectors STINK !
your manual shows this, and stinks.
what stinks worse is no matrix of legal H./V resolutions shown in the manual. (shows only 1)
so set the PC to 1400 x 1050 and do not use others . ok.
and 60Hz, are you in USA? not stated country.
Sony Computers &... | Answered on Nov 28, 2019
no OS stated, W10?
the drivers for your camera/mic are wrong, reload them from SONY..com
Looks like you are having a bad LCD screen, This could be due to drop damage. Cracks can be so tiny and may not be visible immediately. I would take it to a technician and get a screen replacement.
Sony Computers &... | Answered on Nov 27, 2019
Sony mylo COM-2 Logo
24 questions posted
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Computers & Internet
Most Popular Question
forget password mylo 2
  • Computers & Internet
