20 Most Recent General Electric SPEAKER SYSTEM FOR IPOD SPKR Questions & Answers
there is an alternate sound jack. try connecting it to the other device
General Electric... | Answered on Jul 17, 2010
Here is a pdf of the manual >> http://www.lacrossetechnology.com/5220/manual.pdf
Audio Players &... | Answered 10 hours ago
Mine had the same fault. The CD is being rejected as it could not load up - this is probably because of the CD loading mechanism.
You'll need to unplug and remove the case - 4 screws on the sides and 4 or 5 on the back. Once this is done plug back in (be careful not to touch any live parts inside), load a CD and watch. What you'll probably see is that when the drawer closes the mechanism under the drawer doesn't lift sufficiently. Give it small push when it tries and I bet it then will and the CD will play.
What you need to do to fix this is remove the front panel/PCB and also remove the plastic cover that is screwed above the CD drawer so that you can see more of the topside of the mechanism.
Remove the front panel/PCB by releasing the 2 screws on the bottom and then easing forward. Gentle - as there are pins connecting the front PCB to the side PCB. You should then be able to see a worm drive type arrangement that lifts the lower assembly. This will need regreasing (I used vaseline) with a small stick (I used a Q-tip with the bud cut off). You will probably see where the old grease has been pushed out. Once you've done this, reassemble and operate a good few times to work the grease in.
Done! Mine works fine now after sitting there performing the annoying trick you described for many months!
Audio Players &... | Answered Yesterday
1. Defective batteries
2. Defective charger
1. Open internal fuse
2. Power supply failure
No, phones don't have an infra-red transmitter. That would only work if the HK was connected to wifi and HK made an app and the internal circuity and logic to accept it.
Contact HK direct and buy a new remote.
Or
Harman Kardon DPR1001 Remote Control OEM for sale ...
www.ebay.com > ... > Receivers & Amplifiers
+$15.05 shipping. harman/kardon Remote DPR1001 DP1001 - Tested Works ... OEM Harman Kardon HK 3380 Replacement Remote Control For Receiver ... US$54.99 · ‎In stock
Harman Kardon DPR 1001 Digital Receiver ... - Amazon.com
www.amazon.com > Harman-Kardon-Receiver-Disconti...
Buy Harman Kardon DPR 1001 Digital Receiver (Discontinued by ... The receiver comes with Harman Kardon's programmed LCD remote control with EzSet ... I was planning to replace the speakers too, but now I'm having second thoughts!!
Harman Kardon DPR 1001 A/V full digital path receiver with ...
www.crutchfield.com > ... > Home theater receivers
... 1001 Remote. Leave it to Harman Kardon to develop a groundbreaking full digital path receiver. ... Harman Kardon DPR 1001 owner's manual. MFR #DPR ...
Audio Players &... | Answered on Oct 22, 2020
usually, crackling is due to 3 things:
1) the soundcard (or sound device you have them plugged into)
The best way to test this is to plug in another set of speakers or a headset directly to the sound
device, and listen. if you don;t hear the crackling, than consider that idea scrapped.
2.) speaker wiring/cables. Check the wiring for cracks/frayed spots. Do you get any crackling during/after you move the wires? if there is ANY change, for the better or the worse, than you have your culprit.
3.) the speakers themselves. when the first two options above are exhausted, there's only the insides of the speakers themselves to blame. you might not have seen any cone deterioration- but other things could happen, such as deteriorating wiring, etc.
for new speakers, they are relatively cheap- Here in Canada at least, I can get a new 2.1 set for anywhere from $25-60. Although, I'd strongly recommend any of the Logitech brand speakers- most models have subwoofers with unbelievable bass (for the price) through them. I myself have the more expensive Z-5500 series from them (5.1), and I've been more than impressed.
Audio Players &... | Answered on Oct 19, 2020
indeed chaffburner you are not the only one with this problem. over 93% of my searches result in the "monster cable" version of this product. even the RCA site did not have this manual (and the product is just over 5 years old). if anyone out there knows of the whereabouts of the elusive RCA HTS 2600 Home Theater System manual ---in any form--- please drop a line. i'll be happy to pass it along to chaffburner and the other sites that deal with user manual searches. thank you for your energy.
Record players are broadly divided into three groups with the vast majority being either belt drive or the classic drive of a rubber-tyred idler wheel running on the inside of the outer circumference of the platter.
A few are direct drive...
The belt of the belt drive type is the most troublesome due to age affecting the elastic quality of the belt material.
The classic drive is troublesome over the longer period as age hardens the rubber tyre and removes it's natural friction.
The few high quality direct drive types have a small degree of speed adjustment and the correct speed is checked by a stroboscope. In the case of problems with this type the help of a specialist will be needed.
Other drive types exist but are very few and far behind.
Audio Players &... | Answered on Oct 15, 2020
Try to clean it from dust or check something that cover outer body of the openinig if its not came rigth you will use some other methods but try frist this step
Audio Players &... | Answered on Oct 14, 2020
i think you cant convert audio to text using some softare because their quality was not good .Even i suggest you to try www.transcriptionsservice.com to transcribe your audio to text.Because am using their service and their result was good.
Audio Players &... | Answered on Oct 12, 2020
I thought my Pure Sonus 1XT was knackered as it would only show a blank blue screen and not respond to the buttons.
But by trial and error I found that if I disconnected it from the mains power supply for TWO WEEKS (one week was not enough) it would restart correctly, and would stay ok so long as I did not disconnect from the supply, and so I used only the standby button to switch off. If I did disconnect, it meant another two week wait.
No idea why this works. Mine did have a faulty power supply at one time (genuine Pure) which left 15v on the supply, rather than the 9v that it should be.
Worth a try before you take it for recycling.
Beresford.
Audio Players &... | Answered on Oct 09, 2020
See this website - you can download the program, install it and directly convert Youtube music videos into mp3 files. There are 32 and 64 bit versions so just be aware of that.
https://www.4kdownload.com/downloads
Audio Players &... | Answered on Oct 08, 2020
try to reboot
i have three of these in my amp repair shop. one of them does exactly this. as well, the other two are suspect to the same issue. i believe it is low quality leaky or shorting caps. are you using the xlr inputs or 1/4 inch inputs? so far, these are working good thru the 1/4 inch jacks, but the xlr inputs are squeely with feedback and i get that loud bang/pop from one of them. kustom wants me (my shop) to be an authorized repair station for them. i want to be able to resolve these three amps before i accept. if they are a nightmare to deal with, then i will tell them no way.
i will post back with in the next week with more results and hopefully i will have precise solution with parts and procedures.
yost amplifier repair
yostamplifier.com
Audio Players &... | Answered on Oct 04, 2020
Perhaps a reset would help:
https://smallbusiness.chron.com/reset-creative-zen-media-player-65458.html
Audio Players &... | Answered on Oct 02, 2020
http://diagramas.diagramasde.com/audio/HCD-ZX10D.pdf here's the manual for this model. I have the same problem, have'nt managed to turn off demo mode. If you figure it out let me know :-)
Audio Players &... | Answered on Sep 21, 2020
General Electric SPEAKER SYSTEM FOR IPOD SPKR Logo
1 questions posted
Popular Products
Top General Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a General Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • General Audio Players & Recorders
Most Popular Question
like connect ge speaker system
  • Audio Players & Recorders
