20 Most Recent
TREND Motor Trend Inverter 2400 Watt 400-Watt Power Supply Questions & Answers
My Motor Trend Inverter 400 watt give's me a fault
Sadly replacement is the best option. It is just not cost effective to get the inverter repaired.
The cost starts out about 150.00.
Best option is to take it back to where you purchased it and hope you can get a new one.
Hope this tip helps.
Am a seven each power inverters owner.
Recommendations: Purchase a Pure sine inverter 1500 watt. We have had one of these running 24 seven for almost a year now.
Motor trend 2400 watt inverter has 147 VAC from both hot and Neut
Assuming you are testing alternating current and not direct current that sounds quite normal. Plug with confidence. You are using equipment designed for 110v-120v and you're getting 113.8v where it matters most. Higher voltage to ground is nothing unusual, that's just how this inverter is designed.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
