20 Most Recent
HP Compaq Presario V6700TX Notebook Questions & Answers
Webcam
At Hewlett-Packer web site. They are the manufacture for Compaq. Also another source for firmware is : FIRMWAREHQ on the internet...all is free there. Most of the firmware is for older models of 2 to 3 years. never seen any new stuff for brand new computers.
6/5/2013 6:50:03 PM •
HP Compaq...
Answered
on Jun 05, 2013
Looking for webcam driver for v6700 xp
You need to goto the manufacturers website, find
their support section and there should be a list of drivers for your specific
machine. Installing these should resolve your problem. I have a list of links
to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
7/18/2010 9:39:53 AM •
HP Compaq...
Answered
on Jul 18, 2010
How can i unblock myspace from school computer
Your school has a pretty good reason for blocking myspace in school.
To unblock this, you can use a proxy but I am pretty sure that your school may have blocked proxy websites already if their security is good.
try this one : www.nakatago.com
But the shcool's IT may still detect it and block it right away.
5/7/2010 1:54:40 PM •
HP Compaq...
Answered
on May 07, 2010
How to enabled driver from device manager
use your mouse, right click on the driver that you want to enabled,then click on enable.
Or you can click the properties, below the ab box there a selection about enable and disable the driver.
12/8/2009 6:37:58 AM •
HP Compaq...
Answered
on Dec 08, 2009
Sata drives for windows xp
Go here and download Matrix Storage Manger for sata drives, you have to select your OS first >>>>>>
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2101
Once downloaded you have to make a floppy disk or a bootable USB drive so make sure you read all the information first before performing the data transfer to the floppy/USB.
Once your happy that the files are on the media and in the USB port or floppy set the XP install going and watch the screen for the F6 prompt, it will be at the bottom right hand side of the screen and you have to be quick to install the third party drivers.
Good luck.
7/10/2009 6:23:23 PM •
HP Compaq...
Answered
on Jul 10, 2009
Can not setup windows xp sp3 sata on hp compaq
Ok, the problem here is that the Windows XP CD that you have does not have the proper SATA drivers on it already. There are two ways to get around this:
1. Locate the drivers for your SATA controller from HP's website. Copy them to a floppy disk (old 3.5" style) and install the drivers during the installation. When booting up the XP CD, one of the first things it says is "Press F6 to install 3rd party RAID or device drivers". This is where you would press F6. During the install, it would ask you to provide the hard drive controller drivers. Windows XP only allows for these drivers to be installed from a floppy disk, so if your computer doesn't already have a floppy drive, you'll need to get an external USB drive. Once you give XP setup the correct drivers, it can find the hard drive and continue with the installation.
2. Create a custom XP installation CD with the new drivers on it. On another computer with internet, CD-burning capability, and a lot of time and effort, you can slipstream the SATA drivers into the XP CD that you have now. This is not a process for novice users, and can be very time consuming. For a single installation, you're better off with the floppy drive option.
In order to find the correct SATA drivers for your computer, we'll need to know the exact make and model of your computer. The Presario v6700 is a series, there are many models inside of that series. They most likely use the same driver for SATA, but it'd be nice to know exactly which model you have. THis should be printed on the bottom of the laptop.
5/15/2009 10:54:52 PM •
HP Compaq...
Answered
on May 15, 2009
Compac presario CQ62
Hello
Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine.
usually F11 or F10.
others has DVD, check and see what you have of these two.
in the first one, you recover from a disk partition the whole OS.
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too!
but be aware you have to be more specific on model, and BIOS dates.
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
