20 Most Recent Eaton Powerware 9355 UPS System Questions & Answers
Bypass failure is the same as your input unless you have a dual input. You lost power and the UPS did not hold the load because the batteries are bad. Replace the batteries and you will be ok.
Eaton Powerware... | Answered on Mar 02, 2015
Seems to have had a power glitch, is the system back to normal?
Eaton Powerware... | Answered on Jan 05, 2015
it looks like you have a faulty static switch
it indicates you have a polarity issue on your bypass feed. Most likely L1, L2 or L3 are mixed up (rotated). So you are using L2 as L1 or something like that. You should check (measure) the phase rotation/polarity.
Eaton Powerware... | Answered on Dec 13, 2012
the manual covers this, it tells you to read alarm event code
messages they are not in number format but text.
in clear english the alarms.
RTM or call EATON, we are Fixya not EATON,ok>
most error common means bad batteries. 99% are.
http://www.eaton.com/content/dam/eaton/products/backup-power-ups-surge-it-power-distribution/backup-power-ups/eaton-9130-ups/eaton-9130-ups-pdm-user-guide-manual-164201798.pdf
Eaton Computers... | Answered on Dec 08, 2019
Hello Eugene
This is the only post that you have posted here on Fixya dot com, albeit you have posted this same thing twice. Therefore I suspect you asked the question elsewhere and then came here to complain about it!
I suggest you contact Eaton direct by phone.
https://www.fixya.com/users/eugene-loach
Andrew - Fixya Moderator
see the instruction booklet for that - - - or contact eaton directly.
UPS used lead acid batteries which die after 3 or 4 years. Disconnect the power and open it to see which ones it uses. You will know they are dead if they have swollen or melted. Buy replacement batteries.
learn that when you have black out.
the batteries TAKE OVER< and are huge stress on any battery like this,, and when the lights (AC power) turned the UPS tries to charge said batteries and are now bad.
time for new batteries, or let it beep for 24hours and hope the batteries can recover.
the manual tells you how to see if the batteries are bad and with errorcodes, on all UPS made. RTM read the manual first.
no 2 UPS are the same , unless are.
the first is battery voltage under charge, if too low that means
a cell in 1 battery is shorted. as the LOVE TO DO.
no UPS stated, model.
how old are you batterie(s)
charging errors of most kinds means the battery is bad.
they can do that even year old, but mine last about 3 years on avg.
no battery in any USB with Gel Cells, last a long time.
a fraction of all else inside the box. in fact.
buy a new battery and put it in.
Eaton Powerware 9355  UPS System Logo
14 questions posted
Top Eaton Computers & Internet Experts
Gruber Power...
Gruber Power...
jimixclay
Tom Chichester
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Eaton Computers & Internet
Most Popular Question
eaton 9355 20kva system theres alarm
  • Computers & Internet
