20 Most Recent Nintendo DS Lite Pink Console Questions & Answers
My ds lite won't turn on.
Regular tap water contains minerals that are left behind as the water dries out. So, even if you did get all the water out, the minerals can still cause damage. In addition, the DS has a 'soft power switch' and that means that as long as the battery is in the device (as it probably was when sprayed) there is electricity present that can destroy the unit while water is there. Most probably, the water already did some damage when the unit got wet and the minerals and/or previous damage may have finished the job later when the unit was turned on. Some water may have even been left in the system since it can hide in areas that the dry rice will not be able to "draw" out. The best way to dry out a device is quickly remove the battery, take the entire system apart and clean the individual components and run some distilled water over the components to remove the mineral content of tap water before it dries on the boards/contacts. The DS lite system is relatively inexpensive these days, I think your best solution might be buying a good used one off Ebay (units can be had for around $50 today). May want to take apart any cartridge you had in it the old one and check for water in there, just in case, before using it in the new(er) one, too. Sorry for the bad news.
6/16/2014 1:51:57 AM • Nintendo DS Lite... • Answered on Jun 16, 2014
I wot my codes to werk
work? There's usually a special menu for that.
12/4/2013 2:29:33 AM • Nintendo DS Lite... • Answered on Dec 04, 2013
Left hand side of screen not synchronised with the stylus
it needs to be calibrated from the settings
11/30/2013 11:09:42 PM • Nintendo DS Lite... • Answered on Nov 30, 2013
How to change lanuage
just go the settings and there should be a button there, hopefully you figured that out in more than a year... sorry if i didn't help
11/30/2013 11:08:14 PM • Nintendo DS Lite... • Answered on Nov 30, 2013
2answers
Ds lite gets stuck on "loading"
try fomating ur memory card with fat 32 and put this files in geet the green one
http://www.r4i-sdhc.com/downloade.asp
11/20/2012 6:36:29 PM • Nintendo DS Lite... • Answered on Nov 20, 2012
No
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time. Hopefully one of other experts will be able to provide you with a real solution. Thank you for using FixYa.
2/5/2012 6:42:25 PM • Nintendo DS Lite... • Answered on Feb 05, 2012
Error:051099
error code 051100-1
12/6/2011 12:56:11 AM • Nintendo DS Lite... • Answered on Dec 06, 2011
Game cartridge not working on DS lite
repaired or replaced by nintendo at 1-800-255-3700
6/29/2010 7:16:27 PM • Nintendo DS Lite... • Answered on Jun 29, 2010
2answers
Screen shows no game inserted ,when a game is in
Try a cleaning kit and clean the game slot contacts and game cartridge.
4/7/2010 12:38:04 AM • Nintendo DS Lite... • Answered on Apr 07, 2010
The top screen on my ds lite keeps flickering
It might be worth checking the ribbon cable for the top screen is tight in the socket on the main board, this could explain why the screen gets back to normal when you close the ds then reopen. The ribbon cable for the top screen is in the hinge on the left side of the ds when open, the only way to check this is to take the back of the ds, to do this you will need a small philips screw driver and a tri-wing screw driver which you can get of ebay quite cheap. The worst possible fault is the top screen is faulty and needs to be changed, if you do a search in youtube you will find videos on how to do this, they are good and quite detailed. hope this helps.
2/17/2010 9:35:13 PM • Nintendo DS Lite... • Answered on Feb 17, 2010
3answers
R4 wont work on pink ds lite.
well some ds' insides are broken yours mightve been mistreated or the ds is just defective
1/11/2010 2:10:36 AM • Nintendo DS Lite... • Answered on Jan 11, 2010
Slot1 of the nintendo ds lite the metal contacts
Gonna have to call nintendo and see if they repair it.
11/20/2009 9:44:03 PM • Nintendo DS Lite... • Answered on Nov 20, 2009
2answers
DS lite was dropped and now it won't work.
They usually don't work properly after they've been dropped. Nintendo carries a 1 year warranty, they will replace it for free (but not if you've used cheat codes (Action Reply), etc). I wouldn't mention that you've dropped it when calling them.
7/12/2009 6:47:29 PM • Nintendo DS Lite... • Answered on Jul 12, 2009
On My DS Lite I Cannot Do A Wi-Fi Connection....
Well, there are some internet connections that do not work on the DS. The DS only supports WEP-key security. Also, double-check and make sure that you are close enough to the access point. And try to be more specific in descriptions if you want any answers.
7/12/2009 6:45:16 PM • Nintendo DS Lite... • Answered on Jul 12, 2009
I need the walkthrough for the original 'Legend of Zelda'
http://www.zeldadungeon.net/Zelda01-the-legend-of-zelda-walkthrough.php
1/12/2016 11:28:25 PM • Nintendo DS... • Answered on Jan 12, 2016
My black and red wires for my nds speaker circuit boards was severed. Can they still be used or do I need a new circuit board?
If the board (PCB) is not damaged you can re-solder the wires back. If the PCB is damaged you should be able to get new ones by looking up the make and model of the device and look for the specific part.
10/12/2015 12:32:40 AM • Nintendo DS... • Answered on Oct 12, 2015
I cant get my dsi to play games with r4 card,,even had r4 card downloaded with new games
The DSi has several system updates specifically designed to block flashcarts such as the R4. Check the R4 website to see if they have information on what to do if your DSi has blocked the cart. You might be able to do an update to the R4 to fix it. Another option is to get a different cart that has a work-around built in, such as the "SuperCard DSTwo" which has a small chip inside it that other carts don't have and has a file you can download directly onto the memory card that goes into the cart to update it whenever that happens.
8/3/2015 3:01:20 PM • Nintendo DS... • Answered on Aug 03, 2015
Nintendo DS Lite Pink Console Logo
18 questions posted
Popular Products
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Ekse
Aron
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
DS Nintendo
  • DS Nintendo
Most Popular Question
game cartridge not working ds lite
  • Video Game Consoles & Games
