20 Most Recent
Behringer EUROPOWER EP1500 Car Audio Amplifier Questions & Answers
How to bridge the amp
How many channels does the amp have? 1,2,3,4? im going to assume its only a 2 channel amp when I say, there should be a 2 positive and negative channels, do your speaker wires off of 1 positive and 1 negative of the channels to the speaker.
12/11/2009 9:18:43 PM •
Behringer...
Answered
on Dec 11, 2009
Europower 1500 amp
COULD BE FUSES ...CHECK THEM WITH AN OHMS METER.ALSO IT MAY BE THE POWER SWITCH IT MAY HAVE GOT BUMPED AND BROKE INSIDE THE SWITCH JUMP THE SWITCH WITH A JUMPER WIRE BE VERY CAREFULL
NOT TO GET SHOCKED IT COULD HAVE A 120 VOLTS AC AT THE SWITCH GOOD LUCK
4/22/2009 1:04:45 AM •
Behringer...
Answered
on Apr 22, 2009
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
