20 Most Recent Jl Audio Slash v2 500/1v2 Car Audio Amplifier Questions & Answers
I burnt up 4 irfz44v 735p on my Jl Audio 500/1v2
try pacparts.com.
7/25/2011 6:53:34 PM • Jl Audio Slash... • Answered on Jul 25, 2011
Jl Audio Slash v2 500/1v2 Car Audio Amplifier.
I've had similar problems, usually for me it ends up being a bad ground.
2/23/2011 11:19:29 PM • Jl Audio Slash... • Answered on Feb 23, 2011
Have a JL audio slash 500 that isnt putting out
Yes it possible that the inputs have been damaged on the circuit board of the amp. If the amp has hi level inputs you could try running a speaker wire input to it and see if it works. You might try another pair of rca cables to.
8/20/2010 9:53:36 PM • Jl Audio Slash... • Answered on Aug 20, 2010
My sound cuts out and the power light blinks
the amp it going into protect mode because there is an internal fault with the amp. it will need to be repaired. best this to do is find a repair shop and let them handle it good luck man
10/25/2009 5:55:03 AM • Jl Audio Slash... • Answered on Oct 25, 2009
2answers
Amp not putting out on speaker end
The audio amplifier IC´s maybe are fried
4/24/2009 11:47:29 PM • Jl Audio Slash... • Answered on Apr 24, 2009
2answers
My JL audio 1000 x 1 hooked up to 2. 15 Sundowns I play it and then after awhile it shuts down and says low voltage why is this happening
sounds like the amps not rated for the resistance tha subs have it running at....are they a dual 2 or dual 4 ohm?is the amp rated for 1ohm? sounds like amps going into protect mode
7/10/2019 11:59:33 PM • Jl Audio Car... • Answered on Jul 10, 2019
2answers
I have a jl audio jx500-1d went on protection mode and already disconnect every cable to it and try it again but same thing goes to protection mode
Sounds like you either shorted something out or overloaded the amp. Is there any odor coming from it? If so It will need to be repaired or replaced. What did you have connected to it and how was it wired?
5/12/2019 6:00:42 PM • Jl Audio Car... • Answered on May 12, 2019
2answers
JL AUDIO JX 1000.1D protect light comes on some damage to rca's but no visual loose connections ...help
You will need to open it up to see if anything damaged. That does not look good at all from the outside.
5/12/2019 5:52:43 PM • Jl Audio Car... • Answered on May 12, 2019
I have a jl audio jx 1000 .1 and I have two hifonics 12 both are 4 ohms subs how can I wire them to my amp for best results?
In your world, what does best results mean to you. how are the hifonics mounted? open air, closed box, vented box (optimized to what freq)? trunk or inside vehicle? all these variations weigh heavily on your configuration. As does what 'best results" means to you.
11/19/2018 10:02:04 AM • Jl Audio Car... • Answered on Nov 19, 2018
I have a jl audio 250/1v2 when I plug in the power wire it comes on but then Shut off why is that
Check your ground to make sure it is properly grounded
5/2/2017 4:48:18 AM • Jl Audio Car... • Answered on May 02, 2017
Jl audio amplifier keeps going into protection mode
Disconnect all the speakers one at a time and see if it stops doing that, if it does you have a shorted speaker or wiring
11/18/2016 10:55:51 PM • Jl Audio Car... • Answered on Nov 18, 2016
Jl Audio Slash v2 500/1v2 Car Audio Amplifier Logo
Popular Tags
10 questions posted
Top Jl Audio Car Audio & Video Experts
Morne Olivier
Morne Olivier
Mike
Marvin
Marvin
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jl Audio Car Audio & Video
Most Popular Question
amp not putting out speaker end
  • Car Audio & Video
