20 Most Recent
Ulead My Scrapbook® 2 & Paint Shop® 20 Standard Questions & Answers
Drivers install exe
Click
start control panel administration tools computer management device manager
scroll to sound video and game controllers you might see a yellow question /
exclamation? ! mark or a red X Right click to reinstall drivers
If
your computer came with a motherboard disk the drivers could be on it
or
you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a
free driver solutions
which will automatically search for and find the
correct driver
You
will have to update every driver individually once you update you might be
asked whether you want to restart or make a system restore point.
Click
no to both of these then continue updating each driver free then restart once
all of the drivers have been updated.
It might take some time
being free
10/17/2013 3:37:53 AM •
Ulead My...
Answered
on Oct 17, 2013
How Can I Run Ulead Media Studio 7 With Windows 7
Most programs designed for Windows XP will run properly in Windows Vista or Windows 7;
occasionally, you will find one that will not. If you're unable to get a program to operate
normally in Windows 7, try running it in Compatibility Mode.
Perform these steps to setup an application
for Compatibility Mode:
Right-click on the program's shortcut or icon on the disk
click "Properties".
Click the "Compatibility" tab.
Check the box titled "Run this program in compatibility mode for" and select from the
list the version of Windows the program was designed to work with. If you don't know
what Windows version, select "Windows XP (Service Pack 2)"; you can always change it,
if the program does not run with that setting.
Click "OK."
Try running the program again. If you're still unable to use the program, select a different
mode and click other options on the Compatibility tab - i.e., make one change to
a setting, try running the program, make another change, etc., until it runs correctly).
Also, you can run the Program Compatibility
Wizard within Windows Help.
Hope that helps you....
Can not uninstall ulead dvdfactory7
Try using "Uninstall It" for deleting any program from your computer. It's a free open source program you can download from opensource.org completely free and safe to use.
How do I find the serial number?
The serial number is usually on a sticky label on the back of the CD sleeve, or on the folder it came in.
If not get in touch with the maker
