20 Most Recent Samsung PN42A450 Plasma TV Questions & Answers
That TV is covered under a class action settlement from Samsung due to power supply issues. You should be able to get the unit repaired free of charge by contacting Samsung. You can get more information about the class action settlement here:
http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Samsung PN42A450... | Answered on Sep 27, 2019
A new main board should correct the issue
Samsung PN42A450... | Answered on Dec 21, 2017
That is a T-con board or cable issue
Samsung PN42A450... | Answered on Nov 27, 2017
Hi, My name is Amp:
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Samsung PN42A450... | Answered on Sep 21, 2016
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Samsung PN42A450... | Answered on Dec 04, 2014
Depends on your head phones and what type of connector they have. First you'll need to locate the Audio out on the TV which is usually on the back right side. Headphone Jack is located there.
see attached diagram.
if your plasma tv is not gurantee and company is not going to repalace it the price of a plasma panel more or less is about 70 %
of a new plasma tv this means that if a plasma tv is 1000 usd you have to pay at least 700 usd
Samsung PN42A450... | Answered on Oct 17, 2014
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Samsung PN42A450... | Answered on Mar 14, 2014
Refer the user manual to both the devices for details.
Samsung PN42A450... | Answered on Nov 30, 2013
Check and replace its main board. Contact any service technician.
Samsung PN42A450... | Answered on Nov 20, 2013
It is not possible to give you information about this, by this window,because, there is a lot to type in here.
If you wish to get more details about how to check the buffer board, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Samsung PN42A450... | Answered on Oct 05, 2013
Cause to this fault to a plasma can be many. It is not predictable, as the set is hit by lightning stroke. It will be best to contact any experienced service technician to get it repaired. If you wish to get some details about the repair and faults to plasma displays, check the site linked here. Almost all plasmas, irrespective of brand will have the same structure and fault symptoms. http://electronicshelponline.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Samsung PN42A450... | Answered on Aug 26, 2013
Possible burned out light source or power supply. See if bulb is replaceable(SEE MANUAL). UNPLUG POWER, Look for burn damage to bulb. Do not touch bulb with bare hand.
Samsung PN42A450... | Answered on Jul 19, 2012
Samsung PN42A450 Plasma TV Logo
70 questions posted
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
PN Samsung
  • PN Samsung
Most Popular Question
issue volume control both remote tv
  • Televison & Video
