20 Most Recent Syntax-Brillian Olevia 242TFHD 42 in. LCD TV Questions & Answers
How do I fix my OLEVIA 42" flat screen??? Power light comes on the fades
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
9/28/2014 6:39:49 PM • Syntax-Brillian... • Answered on Sep 28, 2014
0answers
I can't get my Olevia tv (537-B11) to scan for channels
I don't know this model of TV, however, you may find that you need to use the Source button on the remote to cycle through the available inputs & select digital tuner as the input source before you press the Menu button & go into the setup section.
1/6/2014 12:55:57 AM • Syntax-Brillian... • Answered on Jan 06, 2014
0answers
My olevia 242-s11 want turn on changed power supply and main board whats next
Two things, assuming you installed a working power supply and main board, check to make sure the kill switch is in the "On" position. If my memory serves me correctly, this set does have one. Are you sure you have a working outlet? power cord? When you say the set won't turn on , are you referring to the entire set or just the screen?
2/9/2013 6:29:22 AM • Syntax-Brillian... • Answered on Feb 09, 2013
Olevia tv won't auto program you can punch in numbers but you cannot channel up it goes into mute
problem with keyboard on set front or side===likely defective switches under the plastic buttons.
5/14/2012 1:26:32 PM • Syntax-Brillian... • Answered on May 14, 2012
Olevia LCD HDTV 242tfhd will not turn on.
See solution above (from John Adams) if that doesn't work it may be the power board which is available on ebay for $69 incl. shipping. Good luck.
4/20/2012 10:24:52 PM • Syntax-Brillian... • Answered on Apr 20, 2012
Standby light is on,but my olevia tv will not turn on.
No, someone will need to open set and check voltages etc and also look at power board to see if any puffed up bad caps like these:4_19_2012_3_55_30_pm.jpg
4/20/2012 10:18:15 PM • Syntax-Brillian... • Answered on Apr 20, 2012
NO SOUND UNTIL TURNED OFF AND ON AT LEAST 8 TIMES
try to fasten on/off knob
2/24/2012 5:42:58 PM • Syntax-Brillian... • Answered on Feb 24, 2012
0answers
Remote codes for olevia tv
I just bought a Sony RM-VLZ620 for about $20 and it comes w/ Olevia codes.
3/5/2011 10:47:43 PM • Syntax-Brillian... • Answered on Mar 05, 2011
Syntax-Brillian Olevia 242TFHD 42 in. LCD TV Logo
68 questions posted
Top Syntax Televison & Video Experts
Jaime Hernandez
Kolbrun...
ray gallant
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Syntax Televison & Video
Most Popular Question
olevia 24242fhd t11 will not turn blue
  • Televison & Video
