20 Most Recent
Samsung DVD-1080P7 DVD Player Questions & Answers
if your television is also samsung just press the tv button and automatically working to your tv,then press the dvd and it work in the dvd.
9/10/2019 12:26:03 PM •
Samsung...
Answered
on Sep 10, 2019
Paused a disc ,when i hit play,the play light
Hi:
Try disconnecting the unit from any power source and waiting for at least 10 mins before restoring power. This should reset the units microprocessor so you can resume playing.
5/1/2011 5:24:28 PM •
Samsung...
Answered
on May 01, 2011
Keep getting a no disk error. how do i fix this?
This can be as simple as a dirty lens as you suspect or a defective optics assembly. Remove the cover and clean the lens with a cotton swab and alcohol. If that fails to allow the unit ti play DVDs, try a CD. If the CD will play, then the unit is likely to require new optics. CDs require less laser power to read then DVDs.
Dan
9/13/2010 12:27:36 AM •
Samsung...
Answered
on Sep 13, 2010
Subtitle too small
better to find orignal firmware for this, for better operation.
11/22/2009 10:00:10 AM •
Samsung...
Answered
on Nov 22, 2009
Dvd disk not work
you can clean your dvd lens with the lens cleaner cd it works if not then go the mechanic and checked it out
7/14/2009 7:19:23 AM •
Samsung...
Answered
on Jul 14, 2009
European DVDS
Turn on (on the remote)
-Wait until appears "no disc"
-Open and shut the tray
-Wait for "no disc" again
-Press REPEAT on remote
-Press 76884 on remote (for region 4. I guess that to other regions the codes below**** will apply)
-When appears the number 4 on TV screen, press number 9 on remote
-Press ENTER
Now you have a region free player!
****Codes for other region players:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
8/24/2008 10:36:35 PM •
Samsung...
Answered
on Aug 24, 2008
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
