20 Most Recent Toshiba SD6100 DVD Player Questions & Answers
2answers
The door of my Toshiba
Try unplugging the DVD player from the outlet for 2-3 minutes to reset the unit. If this doesn't help, the player probably needs to be serviced.
I hope this helps.
(if the unit is out of warranty, you could try opening the case and removing the DVD drive. There should be a manual ejection button hidden on the front of the drive. Unfortunately, doing this to get your DVD out voids the warranty, if it is still under warranty. Each manufacturer puts this button in a different place. On computer drives, the faceplate has a hole to indicate the spot. The ejection usually takes some force with a straightened paperclip (or small allen wrench).)
10/2/2019 8:55:19 PM • Toshiba SD6100... • Answered on Oct 02, 2019
My toshiba sd-6100 DVD player
I doubt it would beep when switched off because when switched off all the circuits would have no power going to them, it would surely beep only when in standby mode and that would probably be a reminder to ensure it is switched off or unplugged when not in use.
9/14/2017 3:01:42 AM • Toshiba SD6100... • Answered on Sep 14, 2017
0answers
Codes
Be the first to answer 2/27/2014 3:14:05 AM • Toshiba SD6100... • Posted on Feb 27, 2014Be the first to answer
0answers
0answers
MY TOSHIBA DVD PLAYER HAS SUDDENLY STARTED
if this is connected with component wiring (red, green, blue for video) check that all 3 wires from DVD to tv are good it souns like one of those wires might have gone bad or got pulled out or moved by mistake. that would be the best place to start - if this doesnt help please write back with as many details as possible and i will try to give you more help
3/29/2011 1:52:43 PM • Toshiba SD6100... • Answered on Mar 29, 2011
How to use dvd's bought
you will need to make it region free
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray; remove any disk and leave the tray open.
3. Press 2403960 then 9 for multi-region playback (or any region number 1-6 it seems). You will *NOT* see any displays indicating that you have entered any numbers! (After the hack when changing the region codes around the set region code will now display where it didn't on the first time hack).
5. The player is now region free !!!
Please vote for me if you found this useful
3/3/2011 3:43:16 PM • Toshiba SD6100... • Answered on Mar 03, 2011
Player will not load disc, continually get bad
Hi gastonth,
Try these basic steps below to solve your problem. You should prepare tools and test instrument like multimeter.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
Ifyou already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I would advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Hope it may help you.
Have a nice day!
2/15/2011 2:55:40 PM • Toshiba SD6100... • Answered on Feb 15, 2011
My remote doesn't work ,
Possible that the remote has a fault within the unit. Please find the following link helpful;
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
2/4/2011 12:31:37 PM • Toshiba SD6100... • Answered on Feb 04, 2011
How to change the region code on Toshiba SD6100?
1/30/2010 11:21:24 PM • Toshiba SD6100... • Answered on Jan 30, 2010
My toshiba SD 6100 dvd player is playing only blue screen
just tried with RCA or the hightdef. cables the one with Green bue and red.
8/25/2009 12:08:33 AM • Toshiba SD6100... • Answered on Aug 25, 2009
Toshiba DVD Player Freezes on a frame after playing a few minues
Have you manually cleaned the laser lens, by removing the outer casing and physically cleaning it with alcohol and a cotton cloth? Have you tried adjusting the angle of the laser lens?
Hope this helps you out.
8/18/2009 4:28:17 PM • Toshiba SD6100... • Answered on Aug 18, 2009
Our toshiba dvd player only displays movies in
replace the mainboard this is a common problem with this dvd im afraid
7/18/2009 11:33:41 PM • Toshiba SD6100... • Answered on Jul 18, 2009
Toshiba SD6100 DVD Player Logo
36 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
remote doesnt work
  • Televison & Video
